Для отображения динамики нашел много подходов.
Черезь кеш.
$regfile = "m8adef.dat" '
$crystal = 8000000 '
' Open "comb.0:9600,8,n,1" For Output As #1
Dim I(6) As Word '
Dim Count As Byte '
Dim Count_blink As Byte '
Dim Sstr As String * 6
Dim Ind_str As String * 1
Dim K As Byte
Dim W As Bit
'===== I2C scl sda
Config Sda = Portc.4 ' I2C Data
Config Scl = Portc.5 ' I2C Clock
Config I2cdelay = 1 ' I2c
I2cinit
Waitms 50
'===== ds3231
Const Ds3231w = &HD0 '
Const Ds3231r = &HD1 '
'=========== DS3231
Declare Sub Ds3231
Dim Tds3231_bcd As Integer
Dim Temper_z As Byte At Tds3231_bcd + 1 Overlay '
Dim Temper_d As Byte At Tds3231_bcd + 0 Overlay '
Dim Tds3231 As Integer
Dim Tds3231_str As String * 5
'===== DS3231
Dim Seco As Byte
Dim Mine As Byte
Dim Hour As Word
Dim Day As Byte
Dim Dat As Byte
Dim Month As Byte
Dim Year As Byte
Dim Seco_bcd As Byte
Dim Mine_bcd As Byte
Dim Hour_bcd As Byte
Dim Day_bcd As Byte
Dim Dat_bcd As Byte
Dim Month_bcd As Byte
Dim Year_bcd As Byte
Dim Secostr As String * 2
Dim Minestr As String * 2
Dim Hourstr As String * 2
' 1 1820
Dim Tds1 As Integer ' 1 0.1. 10 = 1,0
Dim Tds1_str As String * 4
Dim Err_c1 As Bit '
' 2 1820
Dim Tds2 As Integer ' 1 0.1. 10 = 1,0
Dim Tds2_str As String * 4
Dim Err_c2 As Bit '
Ddrb = &B00111111 ' (), 2 ()
Portb = &B00111111 ' ,
Ddrd = &B00111111 ' ()
Portd = &B00000000 '
Const Ds1820 = 100
Config Timer0 = Timer , Prescale = 64 ' (~250 )
On Timer0 Refresh '
Config Timer1 = Timer , Prescale = 8
On Timer1 Pulse
Enable Interrupts '
Enable Timer0 ' ()
Enable Timer1
Start Timer1
Declare Sub Look_timer()
Dig1 Alias Portb.0 : Dig2 Alias Portb.1 : Dig3 Alias Portb.2 : Dig4 Alias Portb.3 : Dig5 Alias Portb.4 : Dig6 Alias Portb.5 : Dot Alias Portd.0
A Alias Portd.1 : B Alias Portd.2 : C Alias Portd.3 : D Alias Portd.4 : E Alias Portd.5
Do '
Gosub Ds3231
Gosub Temper
Gosub Ind '
Pulse:
Incr K
Refresh: ' 0 ( ~4 )
Set Dig1 : Set Dig2 : Set Dig3 : Set Dig4 : Set Dig5 : Set Dig6 : Reset Dot '
Incr Count : If Count > 6 Then Count = 1 '
Incr Count_blink : If Count_blink > 250 Then Count_blink = 1 '
Ind_str = Mid(sstr , Count , 1)
Select Case Ind_str
Case "0" : D = 0 : C = 0 : B = 0 : A = 0 '&b0000
Case "1" : D = 0 : C = 0 : B = 0 : A = 1 '&b0001
Case "2" : D = 0 : C = 0 : B = 1 : A = 0 '&b0010
Case "3" : D = 0 : C = 0 : B = 1 : A = 1 '&b0011
Case "4" : D = 0 : C = 1 : B = 0 : A = 0 '&b0100
Case "5" : D = 0 : C = 1 : B = 0 : A = 1 '&b0101
Case "6" : D = 0 : C = 1 : B = 1 : A = 0 '&b0110
Case "7" : D = 0 : C = 1 : B = 1 : A = 1 '&b0111
Case "8" : D = 1 : C = 0 : B = 0 : A = 0 '&b1000
Case "9" : D = 1 : C = 0 : B = 0 : A = 1 '&b1001
Case " " : D = 1 : C = 1 : B = 1 : A = 1 '&b1111
If W = 1 And Count_blink < 125 Then '
If Count = 2 Or Count = 4 Then Set Dot
If W = 0 Then
If Count = 2 Or Count = 5 Then Set Dot
Select Case Count '
Case 1 : Reset Dig1
Case 2 : Reset Dig2
Case 3 : Reset Dig3
Case 4 : Reset Dig4
Case 5 : Reset Dig5
Case 6 : Reset Dig6
Ind:
If K < 30 Then
Sstr = Hourstr + Minestr + Secostr
W = 1
If Left(tds1_str , 1) = "-" Then
E = 1
E = 0
Tds1_str = Mid(tds1_str , 2 , 3)
Tds2_str = Mid(tds2_str , 2 , 3)
If K => 30 And K < 40 Then
' Sstr = Tds1_str + Tds2_str
Sstr = Tds1_str + Tds3231_str
W = 0
' If K => 40 Then
' Sstr = Tds2_str + " "
' Sstr = Tds3231_str + " "
' W = 0
' End If
If K > 40 Then K = 0
' DS18B20
Temper:
Gosub Look_timer
1wreset Pinc , 0
Gosub Look_timer
If Err = 1 Then
Err_c1 = 1 '
Tds1 = 32767 '
Err_c1 = 0
1wwrite &HCC , 1 , Pinc , 0 ' ROM( )
1wwrite &H44 , 2 , Pinc , 0 ' ( )
' Waitms 94
If Err_c1 = 0 Then
Gosub Look_timer '
1wreset Pinc , 0
Gosub Look_timer
If Err = 1 Then
Tds1 = 32767 '
Else ', ,
1wwrite &HBE , 1 , Pinc , 0
Tds1 = 1wread(2 , Pinc , 0)
Tds1 = Tds1 * 10
Tds1 = Tds1 \ 16
Tds1_str = Str(tds1)
Tds1_str = Format(tds1_str , "+000")
Tds1 = 32767
Tds1_str = " 000"
Gosub Look_timer
1wreset Pinc , 1
Gosub Look_timer
If Err = 1 Then
Err_c2 = 1 '
Tds2 = 32767 '
Err_c2 = 0
1wwrite &HCC , 1 , Pinc , 1 ' ROM( )
1wwrite &H44 , 2 , Pinc , 1 ' ( )
' Waitms 94 ' 9
If Err_c2 = 0 Then
Gosub Look_timer '
1wreset Pinc , 1
Gosub Look_timer
If Err = 1 Then
Tds2 = 32767 '
Else ', ,
1wwrite &HBE , 1 , Pinc , 1
Tds2 = 1wread(2 , Pinc , 1)
Tds2 = Tds2 * 10
Tds2 = Tds2 \ 16
Tds2_str = Str(tds2)
Tds2_str = Format(tds2_str , "+000")
Tds2 = 32767
Tds2_str = " 000"
'===== DS3231
Ds3231:
I2cstart
I2cwbyte Ds3231w
I2cwbyte &H00 '
I2cstart
I2cwbyte Ds3231r
I2crbyte Seco_bcd , Ack
I2crbyte Mine_bcd , Ack
I2crbyte Hour_bcd , Ack
I2crbyte Day_bcd , Ack
I2crbyte Dat_bcd , Ack
I2crbyte Month_bcd , Ack
I2crbyte Year_bcd , Nack
I2cstop
I2cstart '
I2cwbyte Ds3231w '
I2cwbyte &H11 '
I2cstart '
I2cwbyte Ds3231r '
I2crbyte Temper_z , Ack '
I2crbyte Temper_d , Nack '
I2cstop '
Gosub Convert
Convert:
Seco = Makedec(seco_bcd)
Mine = Makedec(mine_bcd)
Hour = Makedec(hour_bcd)
Day = Makedec(day_bcd)
Dat = Makedec(dat_bcd)
Month = Makedec(month_bcd)
Year = Makedec(year_bcd)
If Temper_z < 128 Then
Select Case Temper_d
Case 0 : Temper_d = 0 '0000_0000
Case 64 : Temper_d = 2 '0100_0000
Case 128 : Temper_d = 5 '1000_0000
Case 192 : Temper_d = 7 '1100_0000
Tds3231 = Temper_z * 10
Tds3231 = Tds3231 + Temper_d
Temper_z = Not Temper_z
Temper_d = Not Temper_d
Case 0 : Temper_d = 0 '1111_1111
Case 63 : Temper_d = 2 '0011_1111
Case 127 : Temper_d = 5 '0111_1111
Case 191 : Temper_d = 7 '1011_1111
Tds3231 = Tds3231 * -1
Secostr = Str(seco)
Secostr = Format(secostr , "00")
Minestr = Str(mine)
Minestr = Format(minestr , "00")
Hourstr = Str(hour)
Hourstr = Format(hourstr , "00")
Tds3231_str = Str(tds3231)
Tds3231_str = Format(tds3231_str , "000")
Look_timer:
nop
Loop Until Tcnt0 < Ds1820
