Файлы (обновляется!)
Сообщений 1 страница 8 из 8
Решил вынести файл описания регистров отдельно, так как время от времени всплывают неточности или банальные опечатки.
НЕ РЕКОМЕНДУЕТСЯ! См. ниже!  STC_8H.DAT  (обновление 14-12-2024)
' Обновил 11-12-2024 09:08
[BIT]
ACC = E0
B = F0
PSW = D0
P0 = 80
P1 = 90
P2 = A0
P3 = B0
P4 = c0
P5 = c8
P6 = e8
P7 = f8
SCON = 98
T2CON = C8
IE = A8
IP = B8
TCON = 88
[BYTE]
SP = 81
DPL = 82
DPH = 83
TH0 = 8C
TH1 = 8D
TL0 = 8A
TL1 = 8B
PCON = 87
TMOD = 89
SBUF = 99
T2MOD = C9
TL2 = CC
TH2 = CD
RCAP2L = CA
RCAP2H = CB
AUXR  = 8E
SADDR = A9
IPH  = B7
SADEN = B9
P_SW1 = a2
P_SW2 = ba
S1CON = 9A ' UARTs control register
S1BUF = 9B
S2CON = 9A ' UARTs control register
S2BUF = 9B
S3CON = AC
S3BUF = AD
S4CON = 84
S4BUF = 85
IAP_DATA = c2  ' IAP EEPROM Flash Data Register
IAP_ADDRH = c3   ' IAP Flash Address High Byte
IAP_ADDRL = c4    ' IAP Flash Address Low Byte
IAP_CMD = c5    ' IAP Flash Command Register
IAP_TRIG = c6    ' IAP Flash Trigger register
IAP_CONTR = c7  ' IAP Control Register
IAP_TPS = F5 ' IAP Waiting Time Control Register
WDT_CONTR = C1 ' Watchdog Timer Register
RSTCFG = FF   ' Reset Configuration Register
WKTCL = AA ' Power-down wake-up timer count register
WKTCH = AB ' WKTEN = 7
P0M1 = 93 ' mode register 1
P0M0 = 94 ' mode register 0
P1M1 = 91 ' PnM1.x  PnM0.x  Pn.x mode
P1M0 = 92 '   0   0   Quasi bidirectional mode
P2M1 = 95 '   0   1   Push-pull output mode
P2M0 = 96 '   1   0   High-impedance input mode
P3M1 = b1 '   1   1   Open drain mode
P3M0 = b2
P4M1 = b3
P4M0 = b4
P5M1 = c9
P5M0 = ca
P6M1 = cb
P6M0 = cc
P7M1 = e1
P7M0 = e2
T4T3M = D1
T4H = D2
T4L = D3
T3H = D4
T3L = D5
T2H = d6
T2L = d7
ADC_CONTR = BC  ' control register
ADC_RESh = BD  ' Result High Byte
ADC_RESL= BE  ' Result Low Byte
ADCCFG = DE  '  Configuration Register
SPSTAT = cd ' SPI Register
SPCTL  = ce
SPDAT = cf
CCON = D8 ' PCA
CMOD = D9
CCAPM0 = DA
CCAPM1 = DB
CCAPM2 = DC
CCAPM3 = DD
CCAPM4 = DE
CCAPM5 = DF
CL = E9
CCAP0L = EA
CCAP1L = EB
CCAP2L = EC
CCAP3L = ED
CCAP4L = EE
CCAP5L = EF
CH = F9
CCAP0H = FA
CCAP1H = FB
CCAP2H = FC
CCAP3H = FD
CCAP4H = FE
CCAP5H = FF
PCA_PWM0 = F2
PCA_PWM1 = F3
PCA_PWM2 = F4
PCA_PWM3 = F5
PCA_PWM4 = F6
PCA_PWM5 = F7
[SBIT]
TF1 = 8f
TR1 = 8e
TF0 = 8d
TR0 = 8c
IE1 = 8b
IT1 = 8a
IE0 = 89
IT0 = 88
EA  = AF   ' IE
EPCA_LVD = AE
EADC_SPI = AD
ES  = AC
ET1 = AB
EX1 = AA
ET0 = A9
EX0 = A8
PPCA_LVD = BE  ' IP
PADC_SPI = BD
PS  = BC
PT1 = BB
PX1 = BA
PT0 = B9
PX0 = B8
CY  = d7  ' PSW
AC  = d6
F0  = d5
RS1 = d4
RS0 = d3
OV  = d2
F1 = d1
P  = d0
RD  = b7  ' P3
WR  = b6
T1  = b5
T0  = b4
INT1 = b3
INT0 = b2
TXD = b1
RXD = b0
SM0 = 9f  ' SCON
SM1 = 9e
SM2 = 9d
REN = 9c
TB8 = 9b
RB8 = 9a
TI  = 99
RI  = 98
TF2  = cf  ' T2CON
EXF2 = ce
RCLK = cd
TCLK = cc
EXEN2 =cb
TR2  = ca
C_T2 = c9
CP_RL2= c8
[XBYTE]
CKSEL = FE00 '  Clock selection register
CLKDIV = FE01 ' Clock Division Register
IRCCR = FE02  ' Internal Oscillator control register
XOSCCR = FE03 ' External Oscillator control register
IRC32KCR = FE04 ' Internal 32KHz Oscillator control register
MCLKOCR = FE05 ' Main clock output control register
IRCDB = fe06
IRC48MCR = fe07 '
X32KCR = FE08 ' External 32KHz Oscillator control register
HSCLKDIV = fe0b '
T3T4PIN = FEAC ' T3/T4 Select register
ADCEXCFG = fead
CMPEXCFG = feae
ADCTIM = FEA8 ' Timing Control Register
TM2PS = FEA2 ' Timer2 8-bit Prescaler Register
TM3PS = FEA3 ' Timer3 8-bit Prescaler Register
TM4PS = FEA4 ' Timer4 8-bit Prescaler Register
P0PU = FE10 ' Pull-up resistor control register
P1PU = FE11 ' Internal 4.1K pull-up resistor control bit
P2PU = FE12 ' 0: Disable 4.1K pull-up resistor inside the port
P3PU = FE13 ' 1: Enable 4.1K pull-up resistor inside the port
P4PU = FE14
P5PU = FE15
P6PU = FE16
P7PU = FE17
P0NCS = FE18 ' Schmitt trigger control register
P1NCS = FE19 ' Schmitt trigger control bit:
P2NCS = FE1a ' 0: Enable schmitt trigger function on the port. (Schmitt trigger is enabled by default after power-on reset.)
P3NCS = FE1b ' 1: Disable schmitt trigger function on the port.
P4NCS = FE1c
P5NCS = FE1d
P6NCS = FE1e
P7NCS = FE1f
P0SR = FE20 ' Level Shift Rate Register
P1SR = FE21
P2SR = FE22 ' Level shifting speed control bits:
P3SR = FE23 ' 0: Fast level shifting, and the corresponding up and down impact will be relatively large.
P4SR = FE24 ' 1: Slow level shifting, and the corresponding up and down impact will be relatively small.
P5SR = FE25
P6SR = FE26
P7SR = FE27
P0IE = FE30 '  Input Enable Control Register
P1IE = FE31
P2IE = FE32
P3IE = FE33
P4IE = FE34
P5IE = FE35 ' Digital signal input enable control:
P6IE = FE36 ' 0: Disable digital signal input.
P7IE = FE37 ' 1: Enable digital signal input. If the I/O is used as a digital port, it must be set to 1
P0DR = FE28 ' Drive Current Control Register
P1DR = FE29 ' 0: Enhanced drive ability
P2DR = FE2a ' 1: General drive ability
P3DR = FE2b
P4DR = FE2c
P5DR = FE2d
P6DR = FE2e
P7DR = FE2f
I2ccfg = Fe80
I2cmscr = Fe81
I2cmsst = Fe82
I2cslcr = Fe83
I2cslst = Fe84
I2csladr = Fe85
I2ctxd = Fe86
I2crxd = Fe87
I_tksu  = 011B
I_rtc  = 0123
I_p0int  = 012B
I_p1int  = 0133
I_p2int  = 013B
I_p3int  = 0143
I_p4int  = 014B
I_p5int  = 0153
I_p6int  = 015B
I_p7int  = 0163
I_dma_m2m  = 017B
I_dma_adc  = 0183
I_dma_spi  = 018B
I_dma_ur1t  = 0193
I_dma_ur1r  = 019B
I_dma_ur2t  = 01A3
I_dma_ur2r  = 01AB
I_dma_ur3t  = 01B3
I_dma_ur3r  = 01BB
I_dma_ur4t  = 01C3
I_dma_ur4r  = 01CB
I_dma_lcm  = 01D3
I_lcm  = 01DB
Pwm1_etrps = Feb0
Pwm1_eno = feb1
Pwm1_ps = feb2
Pwm1_ioaux = feb3
Pwm2_etrps = feb4
Pwm2_eno = feb5
Pwm2_ps = feb6
Pwm2_ioaux = feb7
Pwm1_cr1 = fec0
Pwm1_cr2 = fec1
Pwm1_smcr = fec2
Pwm1_etr = fec3
Pwm1_ier = fec4
Pwm1_sr1 = fec5
Pwm1_sr2 = fec6
Pwm1_egr = fec7
Pwm1_ccmr1 = fec8
Pwm1_ccmr2 = fec9
Pwm1_ccmr3 = feca
Pwm1_ccmr4 = fecb
Pwm1_ccer1 = fecc
Pwm1_ccer2 = fecd
Pwm1_cntr = fece
Pwm1_cntrh = fece
Pwm1_cntrl = fecf
Pwm1_pscr = fed0
Pwm1_pscrh = fed0
Pwm1_pscrl = fed1
Pwm1_arr = fed2
Pwm1_arrh = fed2
Pwm1_arrl = fed3
Pwm1_rcr = fed4
Pwm1_ccr1 = fed5
Pwm1_ccr1h = fed5
Pwm1_ccr1l = fed6
Pwm1_ccr2 = fed7
Pwm1_ccr2h = fed7
Pwm1_ccr2l = fed8
Pwm1_ccr3 = fed9
Pwm1_ccr3h = fed9
Pwm1_ccr3l = feda
Pwm1_ccr4 = fedb
Pwm1_ccr4h = fedb
Pwm1_ccr4l = fedc
Pwm1_bkr = fedd
Pwm1_dtr = fede
Pwm1_oisr = fedf
Pwm2_cr1 = fee0
Pwm2_cr2 = fee1
Pwm2_smcr = fee2
Pwm2_etr = fee3
Pwm2_ier = fee4
Pwm2_sr1 = fee5
Pwm2_sr2 = fee6
Pwm2_egr = fee7
Pwm2_ccmr1 = fee8
Pwm2_ccmr2 = fee9
Pwm2_ccmr3 = feea
Pwm2_ccmr4 = feeb
Pwm2_ccer1 = feec
Pwm2_ccer2 = feed
Pwm2_cntr = feee
Pwm2_cntrh = feee
Pwm2_cntrl = feef
Pwm2_pscr = fef0
Pwm2_pscrh = fef0
Pwm2_pscrl = fef1
Pwm2_arr = fef2
Pwm2_arrh = fef2
Pwm2_arrl = fef3
Pwm2_rcr = fef4
Pwm2_ccr1 = fef5
Pwm2_ccr1h = fef5
Pwm2_ccr1l = fef6
Pwm2_ccr2 = fef7
Pwm2_ccr2h = fef7
Pwm2_ccr2l = fef8
Pwm2_ccr3 = fef9
Pwm2_ccr3h = fef9
Pwm2_ccr3l = fefa
Pwm2_ccr4 = fefb
Pwm2_ccr4h = fefb
Pwm2_ccr4l = fefc
Pwm2_bkr = fefd
Pwm2_dtr = fefe
Pwm2_oisr = feff
Pwma_etrps = feb0
Pwma_eno = feb1
Pwma_ps = feb2
Pwma_ioaux = feb3
Pwmb_etrps = feb4
Pwmb_eno = feb5
Pwmb_ps = feb6
Pwmb_ioaux = feb7
Pwma_cr1 = fec0
Pwma_cr2 = fec1
Pwma_smcr = fec2
Pwma_etr = fec3
Pwma_ier = fec4
Pwma_sr1 = fec5
Pwma_sr2 = fec6
Pwma_egr = fec7
Pwma_ccmr1 = fec8
Pwma_ccmr2 = fec9
Pwma_ccmr3 = feca
Pwma_ccmr4 = fecb
Pwma_ccer1 = fecc
Pwma_ccer2 = fecd
'Pwma_cntr = fece
Pwma_cntrh = fece
Pwma_cntrl = fecf
'Pwma_pscr = fed0
Pwma_pscrh = fed0
Pwma_pscrl = fed1
'Pwma_arr = fed
Pwma_arrh = fed2
Pwma_arrl = fed3
Pwma_rcr = fed4
'Pwma_ccr1 = fed5
Pwma_ccr1h = fed5
Pwma_ccr1l = fed6
'Pwma_ccr2 = fed7
Pwma_ccr2h = fed7
Pwma_ccr2l = fed8
'Pwma_ccr3 = fed9
Pwma_ccr3h = fed9
Pwma_ccr3l = feda
Pwma_ccr4 = fedb
Pwma_ccr4h = fedb
Pwma_ccr4l = fedc
Pwma_bkr = fedd
Pwma_dtr = fede
Pwma_oisr = fedf
Pwmb_cr1 = fee0
Pwmb_cr2 = fee1
Pwmb_smcr = fee2
Pwmb_etr = fee3
Pwmb_ier = fee4
Pwmb_sr1 = fee5
Pwmb_sr2 = fee6
Pwmb_egr = fee7
Pwmb_ccmr1 = fee8
Pwmb_ccmr2 = fee9
Pwmb_ccmr3 = feea
Pwmb_ccmr4 = feeb
Pwmb_ccer1 = feec
Pwmb_ccer2 = feed
'Pwmb_cntr = feee
Pwmb_cntrh = feee
Pwmb_cntrl = feef
'Pwmb_pscr = fef0
Pwmb_pscrh = fef0
Pwmb_pscrl = fef1
'Pwmb_arr = fef2
Pwmb_arrh = fef2
Pwmb_arrl = fef3
Pwmb_rcr = fef4
'Pwmb_ccr5 = fef5
Pwmb_ccr5h = fef5
Pwmb_ccr5l = fef6
'Pwmb_ccr6 = fef7
Pwmb_ccr6h = fef7
Pwmb_ccr6l = fef8
'Pwmb_ccr7 = fef9
Pwmb_ccr7h = Fef9
Pwmb_ccr7l = Fefa
'Pwmb_ccr8 = Fefb
Pwmb_ccr8h = Fefb
Pwmb_ccr8l = fefc
Pwmb_bkr = Fefd
Pwmb_dtr = Fefe
Pwmb_oisr = Feff
[MISC]
up = STC8H
IRAM = 128
clockdiv = 1
org = DE
I_adc  = 2B
I_lvd = 33
I_uart2 = 43
I_spi = 4B
I_int2 = 53
I_int3 = 5B
I_TIMER2 = 63
I_int4  = 83
I_uart3  = 8B
I_uart4  = 93
I_TIMER3  = 9B
I_TIMER4  = A3
I_cmp  = AB
I_i2c  = C3
I_usb  = CB
I_pwma  = D3
I_pwmb  = DB
Выводы STC8H1K08:
https://forumupload.ru/uploads/0000/25/b8/439/t510217.jpg
Описание к серии ST8H:
http://www.stcmicro.com/datasheet/STC8H-en.pdf
Обновление:  9 Марта 2022
8H1K08.DAT для SCT8H1K08
Отличия от DAT-файла всей серии STC8H: Убраны прерывания, которых в нём нет.
Будут проводиться опыты по расположению области обработки прерываний, но это позже.
14-12-2024
8H1K08.DAT
[BIT]
ACC = E0
B = F0
PSW = D0
P0 = 80
P1 = 90
P2 = A0
P3 = B0
P4 = c0
P5 = c8
P6 = e8
P7 = f8
SCON = 98
T2CON = C8
IE = A8
IP = B8
TCON = 88
[BYTE]
IE2 = AF
SP = 81
DPL = 82
DPH = 83
TH0 = 8C
TH1 = 8D
TL0 = 8A
TL1 = 8B
PCON = 87
TMOD = 89
SBUF = 99
T2MOD = C9
TL2 = CC
TH2 = CD
RCAP2L = CA
RCAP2H = CB
AUXR  = 8E
SADDR = A9
IPH  = B7
SADEN = B9
P_SW1 = a2
P_SW2 = ba
S1BUF = 9B
S2BUF = 9B
S3CON = AC
S3BUF = AD
S4CON = 84
S4BUF = 85
P1M1 = 91 ' mode register
P1M0 = 92 ' PnM1.x  PnM0.x  Pn.x mode
P3M1 = b1 '   0   0   Quasi bidirectional mode
P3M0 = b2 '   0   1   Push-pull output mode
P5M1 = c9 '   1   0   High-impedance input mode
P5M0 = ca '   1   1   Open drain mode
T3H = D4
T3L = D5
T2H = d6
T2L = d7
SPCTL  = ce
SPDAT  = cf
CCON  = D8
CMOD  = D9
[SBIT]
TF1 = 8f
TR1 = 8e
TF0 = 8d
TR0 = 8c
IE1 = 8b
IT1 = 8a
IE0 = 89
IT0 = 88
EA  = AF
'IE2 = AF
EPCA_LVD = AE
EADC_SPI = AD
ES  = AC
ET1 = AB
EX1 = AA
ET0 = A9
EX0 = A8
PPCA_LVD = BE  ' IP
PADC_SPI = BD
PS  = BC
PT1 = BB
PX1 = BA
PT0 = B9
PX0 = B8
CY  = d7  ' PSW
AC  = d6
F0  = d5
RS1 = d4
RS0 = d3
OV  = d2
F1 = d1
P  = d0
RD  = b7  ' P3
WR  = b6
T1  = b5
T0  = b4
INT1 = b3
INT0 = b2
TXD = b1
RXD = b0
SM0 = 9f  ' SCON
SM1 = 9e
SM2 = 9d
REN = 9c
TB8 = 9b
RB8 = 9a
TI  = 99
RI  = 98
TF2  = cf  ' T2CON
EXF2 = ce
RCLK = cd
TCLK = cc
EXEN2 =cb
TR2  = ca
C_T2 = c9
CP_RL2= c8
[XBYTE]
HIRCCR = FE02  ' Internal Oscillator control register
IRCDB = fe06
P3PU = FE13 ' 0: Disable 4.1K pull-up resistor inside the port
P5PU = FE15' 1: Enable 4.1K pull-up resistor inside the port
P3NCS = FE1b ' 0: Enable schmitt trigger function on the port. (Schmitt trigger is enabled by default after power-on reset.)
P5NCS = FE1d ' 1: Disable schmitt trigger function on the port.
P1SR = FE21 ' Level Shift Rate Register
P5SR = FE25' 1: Slow level shifting, and the corresponding up and down impact will be relatively small.
P1IE = FE31 ' Digital signal input enable control:
P3IE = FE33' 0: Disable digital signal input.
P5IE = FE35 ' 1: Enable digital signal input. If the I/O is used as a digital port, it must be set to 1
P1DR = FE29  ' Drive Current Control Register
P3DR = FE2b' 0: Enhanced drive ability
P5DR = FE2d ' 1: General drive ability
I2ccfg = Fe80
I2cmscr = Fe81
I2cmsst = Fe82
I2cslcr = Fe83
I2cslst = Fe84
I2csladr = Fe85
I2ctxd = Fe86
I2crxd = Fe87
Pwm1_etrps = Feb0
Pwm1_eno = feb1
Pwm1_ps = feb2
Pwm1_ioaux = feb3
Pwm2_etrps = feb4
Pwm2_eno = feb5
Pwm2_ps = feb6
Pwm2_ioaux = feb7
Pwm1_cr1 = fec0
Pwm1_cr2 = fec1
Pwm1_smcr = fec2
Pwm1_etr = fec3
Pwm1_ier = fec4
Pwm1_sr1 = fec5
Pwm1_sr2 = fec6
Pwm1_egr = fec7
Pwm1_ccmr1 = fec8
Pwm1_ccmr2 = fec9
Pwm1_ccmr3 = feca
Pwm1_ccmr4 = fecb
Pwm1_ccer1 = fecc
Pwm1_ccer2 = fecd
'Pwm1_cntr = fece
Pwm1_cntrh = fece
Pwm1_cntrl = fecf
'Pwm1_pscr = fed0
Pwm1_pscrh = fed0
Pwm1_pscrl = fed1
'Pwm1_arr = fed2
Pwm1_arrh = fed2
Pwm1_arrl = fed3
Pwm1_rcr = fed4
'Pwm1_ccr1 = fed5
Pwm1_ccr1h = fed5
Pwm1_ccr1l = fed6
'Pwm1_ccr2 = fed7
Pwm1_ccr2h = fed7
Pwm1_ccr2l = fed8
'Pwm1_ccr3 = fed9
Pwm1_ccr3h = fed9
Pwm1_ccr3l = feda
'Pwm1_ccr4 = fedb
Pwm1_ccr4h = fedb
Pwm1_ccr4l = fedc
Pwm1_bkr = fedd
Pwm1_dtr = fede
Pwm1_oisr = fedf
Pwm2_cr1 = fee0
Pwm2_cr2 = fee1
Pwm2_smcr = fee2
Pwm2_etr = fee3
Pwm2_ier = fee4
Pwm2_sr1 = fee5
Pwm2_sr2 = fee6
Pwm2_egr = fee7
Pwm2_ccmr1 = fee8
Pwm2_ccmr2 = fee9
Pwm2_ccmr3 = feea
Pwm2_ccmr4 = feeb
Pwm2_ccer1 = feec
Pwm2_ccer2 = feed
'Pwm2_cntr = feee
Pwm2_cntrh = feee
Pwm2_cntrl = feef
'Pwm2_pscr = fef0
Pwm2_pscrh = fef0
Pwm2_pscrl = fef1
'Pwm2_arr = fef2
Pwm2_arrh = fef2
Pwm2_arrl = fef3
'Pwm2_rcr = fef4
Pwm2_ccr1 = fef5
Pwm2_ccr1h = fef5
Pwm2_ccr1l = fef6
'Pwm2_ccr2 = fef7
Pwm2_ccr2h = fef7
Pwm2_ccr2l = fef8
'Pwm2_ccr3 = fef9
Pwm2_ccr3h = fef9
Pwm2_ccr3l = fefa
'Pwm2_ccr4 = fefb
Pwm2_ccr4h = fefb
Pwm2_ccr4l = fefc
'Pwm2_bkr = fefd
Pwm2_dtr = fefe
Pwm2_oisr = feff
Pwma_etrps = feb0
Pwma_eno = feb1
Pwma_ps = feb2
Pwma_ioaux = feb3
Pwmb_etrps = feb4
Pwmb_eno = feb5
Pwmb_ps = feb6
Pwmb_ioaux = feb7
Pwma_cr1 = fec0
Pwma_cr2 = fec1
Pwma_smcr = fec2
Pwma_etr = fec3
Pwma_ier = fec4
Pwma_sr1 = fec5
Pwma_sr2 = fec6
Pwma_egr = fec7
Pwma_ccmr1 = fec8
Pwma_ccmr2 = fec9
Pwma_ccmr3 = feca
Pwma_ccmr4 = fecb
Pwma_ccer1 = fecc
Pwma_ccer2 = fecd
'Pwma_cntr = fece
Pwma_cntrh = fece
Pwma_cntrl = fecf
'Pwma_pscr = fed0
Pwma_pscrh = fed0
Pwma_pscrl = fed1
'Pwma_arr = fed
Pwma_arrh = fed2
Pwma_arrl = fed3
Pwma_rcr = fed4
'Pwma_ccr1 = fed5
Pwma_ccr1h = fed5
Pwma_ccr1l = fed6
'Pwma_ccr2 = fed7
Pwma_ccr2h = fed7
Pwma_ccr2l = fed8
'Pwma_ccr3 = fed9
Pwma_ccr3h = fed9
Pwma_ccr3l = feda
'Pwma_ccr4 = fedb
Pwma_ccr4h = fedb
Pwma_ccr4l = fedc
Pwma_bkr = fedd
Pwma_dtr = fede
Pwma_oisr = fedf
Pwmb_cr1 = fee0
Pwmb_cr2 = fee1
Pwmb_smcr = fee2
Pwmb_etr = fee3
Pwmb_ier = fee4
Pwmb_sr1 = fee5
Pwmb_sr2 = fee6
Pwmb_egr = fee7
Pwmb_ccmr1 = fee8
Pwmb_ccmr2 = fee9
Pwmb_ccmr3 = feea
Pwmb_ccmr4 = feeb
Pwmb_ccer1 = feec
Pwmb_ccer2 = feed
'Pwmb_cntr = feee
Pwmb_cntrh = feee
Pwmb_cntrl = feef
'Pwmb_pscr = fef0
Pwmb_pscrh = fef0
Pwmb_pscrl = fef1
'Pwmb_arr = fef2
Pwmb_arrh = fef2
Pwmb_arrl = fef3
Pwmb_rcr = fef4
'Pwmb_ccr5 = fef5
Pwmb_ccr5h = fef5
Pwmb_ccr5l = fef6
'Pwmb_ccr6 = fef7
Pwmb_ccr6h = fef7
Pwmb_ccr6l = fef8
'Pwmb_ccr7 = fef9
Pwmb_ccr7h = Fef9
Pwmb_ccr7l = Fefa
'Pwmb_ccr8 = Fefb
Pwmb_ccr8h = Fefb
Pwmb_ccr8l = fefc
Pwmb_bkr = Fefd
Pwmb_dtr = Fefe
Pwmb_oisr = Feff
[MISC]
up = STC8H1K08
I_adc = 2B
I_lvd = 33
I_pca = 3B
I_uart2 = 43
I_spi = 4B
I_int2 = 53
I_int3 = 5B
I_TIMER2 = 63
I_int4 = 83
I_tmr3  = 9B
I_i2c = C3
I_pwma = D3
I_pwmb = DB
org = DE
IRAM = 256
clockdiv = 1
' Обновил 22-11-2024 23:16
i post as reply becaus e i dont see a "create new thread" options
i found this COMMAND LINE programmer -> https://github.com/IOsetting/stc8prog   win32 ->https://filetransfer.io/manage-package/8lrQIjdN
its a bit old.. for me here fails to use USB>serial, but only works with PCI card serial card,
on top of that, fails to my stc8h1k17 with "uknown error code f847"  (chip is supported one)
my guess is that MCU has newer firmware bootloader, since i had same problem with STC's official flasher, until a new version released
my bootloader is
" MCU type: STC8H1K17T
  S/W protocol, V3.0: 7.4.5U"
would be interest to know if works with  other chip's , since a CMD line helps a LOT!
why such difficulties?
There is a standard program for a chip manufacturer stcai-isp-v6.94E.exe. I use it to download firmware
Specify in this program the path to the file that needs to be downloaded and check the box to download a new version of the file when it changes.
After compilation, the file will be loaded into the chip.
зачем такие сложности?
Есть типовая программа производителя чипов stcai-isp-v6.94E.exe. Я применяю её для загрузки прошивки.
Укажите в этой программе путь к файлу, который необходимо загружать и установите "галочку" для загрузки новой версии файла при его изменении.
После компиляции файл будет загружен в чип.
https://forumupload.ru/uploads/0000/25/b8/439/t115418.jpg
i dont have problem with latest version of manufacturer program stcai-isp , i have problem with stc8prog, which is a github, open source program
the reason i try and investigate the stc8prog is because is command line, while stcai-isp is NOT.
a command line utily can be used in
1) bascom/external programer for direct programming
2) for custom batchfile creation where i can in production level
3) in a batchfile from customized programing etc
Christos,
There are two of us on this forum who are interested in these chips.  :dontknow:
I am not using an external program. Therefore, you should write to the author of this program directly.
на этом форуме нас двое, кому интересны эти чипы.
Я не применяю внешнюю программу. Поэтому вам следует писать автору этой программы напрямую.
STC8H1K28.DAT для Bascom-8051
22-11-2024
STC8H1K28.DAT
[BIT]
ACC = E0
B = F0
PSW = D0
P0 = 80
P1 = 90
P2 = A0
P3 = B0
P4 = c0
P5 = c8
P6 = e8
P7 = f8
SCON = 98
T2CON = C8
IE = A8
IP = B8
TCON = 88
[BYTE]
SP = 81
DPL = 82
DPH = 83
TH0 = 8C
TH1 = 8D
TL0 = 8A
TL1 = 8B
PCON = 87
TMOD = 89
SBUF = 99
T2MOD = C9
TL2 = CC
TH2 = CD
RCAP2L = CA
RCAP2H = CB
AUXR  = 8E
SADDR = A9
IPH  = B7
SADEN = B9
P_SW1 = a2
P_SW2 = ba
T2H = d6
T2L = d7
S1BUF = 9B
S2BUF = 9B
S3CON = AC
S3BUF = AD
S4CON = 84
S4BUF = 85
P3M0 = b2
P5M1 = c9
P5M0 = ca
T4T3M = D1
T4H = D2
T4L = D3
T3H = D4
T3L = D5
T2H = d6
T2L = d7
SPCTL  = ce
SPDAT  = cf
CCON  = D8 ' PCA
CMOD  = D9
[SBIT]
TF1 = 8f
TR1 = 8e
TF0 = 8d
TR0 = 8c
IE1 = 8b
IT1 = 8a
IE0 = 89
IT0 = 88
EA  = AF   ' IE
EPCA_LVD = AE
EADC_SPI = AD
ES  = AC
ET1 = AB
EX1 = AA
ET0 = A9
EX0 = A8
PPCA_LVD = BE  ' IP
PADC_SPI = BD
PS  = BC
PT1 = BB
PX1 = BA
PT0 = B9
PX0 = B8
CY  = d7  ' PSW
AC  = d6
F0  = d5
RS1 = d4
RS0 = d3
OV  = d2
F1 = d1
P  = d0
RD  = b7  ' P3
WR  = b6
T1  = b5
T0  = b4
INT1 = b3
INT0 = b2
TXD = b1
RXD = b0
SM0 = 9f  ' SCON
SM1 = 9e
SM2 = 9d
REN = 9c
TB8 = 9b
RB8 = 9a
TI  = 99
RI  = 98
TF2  = cf  ' T2CON
EXF2 = ce
RCLK = cd
TCLK = cc
EXEN2 =cb
TR2  = ca
C_T2 = c9
CP_RL2= c8
[XBYTE]
P5PU = FE15
P5NCS = FE1d
P1SR = FE21
P5SR = FE25 ' 1: Slow level shifting, and the corresponding up and down impact will be relatively small.
P2IE = FE32 ' 0: Disable digital signal input.
P3IE = FE33  ' 1: Enable digital signal input. If the I/O is used as a digital port, it must be set to 1
P5IE = FE35
P3DR = FE2b
P5DR = FE2d
I2ccfg = Fe80
I2cmscr = Fe81
I2cmsst = Fe82
I2cslcr = Fe83
I2cslst = Fe84
I2csladr = Fe85
I2ctxd = Fe86
I2crxd = Fe87
Pwm1_etrps = Feb0
Pwm1_eno = feb1
Pwm1_ps = feb2
Pwm1_ioaux = feb3
Pwm2_etrps = feb4
Pwm2_eno = feb5
Pwm2_ps = feb6
Pwm2_ioaux = feb7
Pwm1_cr1 = fec0
Pwm1_cr2 = fec1
Pwm1_smcr = fec2
Pwm1_etr = fec3
Pwm1_ier = fec4
Pwm1_sr1 = fec5
Pwm1_sr2 = fec6
Pwm1_egr = fec7
Pwm1_ccmr1 = fec8
Pwm1_ccmr2 = fec9
Pwm1_ccmr3 = feca
Pwm1_ccmr4 = fecb
Pwm1_ccer1 = fecc
Pwm1_ccer2 = fecd
'Pwm1_cntr = fece
Pwm1_cntrh = fece
Pwm1_cntrl = fecf
'Pwm1_pscr = fed0
Pwm1_pscrh = fed0
Pwm1_pscrl = fed1
'Pwm1_arr = fed2
Pwm1_arrh = fed2
Pwm1_arrl = fed3
Pwm1_rcr = fed4
'Pwm1_ccr1 = fed5
Pwm1_ccr1h = fed5
Pwm1_ccr1l = fed6
'Pwm1_ccr2 = fed7
Pwm1_ccr2h = fed7
Pwm1_ccr2l = fed8
'Pwm1_ccr3 = fed9
Pwm1_ccr3h = fed9
Pwm1_ccr3l = feda
'Pwm1_ccr4 = fedb
Pwm1_ccr4h = fedb
Pwm1_ccr4l = fedc
Pwm1_bkr = fedd
Pwm1_dtr = fede
Pwm1_oisr = fedf
Pwm2_cr1 = fee0
Pwm2_cr2 = fee1
Pwm2_smcr = fee2
Pwm2_etr = fee3
Pwm2_ier = fee4
Pwm2_sr1 = fee5
Pwm2_sr2 = fee6
Pwm2_egr = fee7
Pwm2_ccmr1 = fee8
Pwm2_ccmr2 = fee9
Pwm2_ccmr3 = feea
Pwm2_ccmr4 = feeb
Pwm2_ccer1 = feec
Pwm2_ccer2 = feed
'Pwm2_cntr = feee
Pwm2_cntrh = feee
Pwm2_cntrl = feef
'Pwm2_pscr = fef0
Pwm2_pscrh = fef0
Pwm2_pscrl = fef1
'Pwm2_arr = fef2
Pwm2_arrh = fef2
Pwm2_arrl = fef3
'Pwm2_rcr = fef4
Pwm2_ccr1 = fef5
Pwm2_ccr1h = fef5
Pwm2_ccr1l = fef6
'Pwm2_ccr2 = fef7
Pwm2_ccr2h = fef7
Pwm2_ccr2l = fef8
'Pwm2_ccr3 = fef9
Pwm2_ccr3h = fef9
Pwm2_ccr3l = fefa
'Pwm2_ccr4 = fefb
Pwm2_ccr4h = fefb
Pwm2_ccr4l = fefc
'Pwm2_bkr = fefd
Pwm2_dtr = fefe
Pwm2_oisr = feff
Pwma_etrps = feb0
Pwma_eno = feb1
Pwma_ps = feb2
Pwma_ioaux = feb3
Pwmb_etrps = feb4
Pwmb_eno = feb5
Pwmb_ps = feb6
Pwmb_ioaux = feb7
Pwma_cr1 = fec0
Pwma_cr2 = fec1
Pwma_smcr = fec2
Pwma_etr = fec3
Pwma_ier = fec4
Pwma_sr1 = fec5
Pwma_sr2 = fec6
Pwma_egr = fec7
Pwma_ccmr1 = fec8
Pwma_ccmr2 = fec9
Pwma_ccmr3 = feca
Pwma_ccmr4 = fecb
Pwma_ccer1 = fecc
Pwma_ccer2 = fecd
'Pwma_cntr = fece
Pwma_cntrh = fece
Pwma_cntrl = fecf
'Pwma_pscr = fed0
Pwma_pscrh = fed0
Pwma_pscrl = fed1
'Pwma_arr = fed
Pwma_arrh = fed2
Pwma_arrl = fed3
Pwma_rcr = fed4
'Pwma_ccr1 = fed5
Pwma_ccr1h = fed5
Pwma_ccr1l = fed6
'Pwma_ccr2 = fed7
Pwma_ccr2h = fed7
Pwma_ccr2l = fed8
'Pwma_ccr3 = fed9
Pwma_ccr3h = fed9
Pwma_ccr3l = feda
'Pwma_ccr4 = fedb
Pwma_ccr4h = fedb
Pwma_ccr4l = fedc
Pwma_bkr = fedd
Pwma_dtr = fede
Pwma_oisr = fedf
Pwmb_cr1 = fee0
Pwmb_cr2 = fee1
Pwmb_smcr = fee2
Pwmb_etr = fee3
Pwmb_ier = fee4
Pwmb_sr1 = fee5
Pwmb_sr2 = fee6
Pwmb_egr = fee7
Pwmb_ccmr1 = fee8
Pwmb_ccmr2 = fee9
Pwmb_ccmr3 = feea
Pwmb_ccmr4 = feeb
Pwmb_ccer1 = feec
Pwmb_ccer2 = feed
'Pwmb_cntr = feee
Pwmb_cntrh = feee
Pwmb_cntrl = feef
'Pwmb_pscr = fef0
Pwmb_pscrh = fef0
Pwmb_pscrl = fef1
'Pwmb_arr = fef2
Pwmb_arrh = fef2
Pwmb_arrl = fef3
Pwmb_rcr = fef4
'Pwmb_ccr5 = fef5
Pwmb_ccr5h = fef5
Pwmb_ccr5l = fef6
'Pwmb_ccr6 = fef7
Pwmb_ccr6h = fef7
Pwmb_ccr6l = fef8
'Pwmb_ccr7 = fef9
Pwmb_ccr7h = Fef9
Pwmb_ccr7l = Fefa
'Pwmb_ccr8 = Fefb
Pwmb_ccr8h = Fefb
Pwmb_ccr8l = fefc
Pwmb_bkr = Fefd
Pwmb_dtr = Fefe
Pwmb_oisr = Feff
[MISC]
up = STC8H1K28
I_adc = 2B
I_lvd = 33
I_pca = 3B
I_uart2 = 43
I_spi = 4B
I_int2 = 53
I_int3 = 5B
I_TIMER2 = 63
I_user = 6B
I_int4 = 83
I_cmp = AB
I_i2c = C3
I_pwma = D3
I_pwmb = DB
org = DE
IRAM = 256
clockdiv = 1
