Прерывания INT0 и INT1 работают, режимы "по фронту, по изменению" - работают.
$regfile = "STC_8H.DAT" ' STC registers list
$crystal = 11059200 ' CPU clock frequence
$ramsize = &H400 ' 1024
$romstart = &H0 ' code starting address
$large
Dim Temp As Byte
P1ie = &B_0000_0100 ' 1: Enable digital signal input
P1m1 = &B_0000_0000 : P1m0 = &B_0011_0000 ' Push-pull output mode
P1pu = &B_0000_0100 ' 1: pull-up resistor
Test_out Alias P1.4
My_led Alias P1.5
P3ie = &B_0000_1100 ' 1: Enable digital signal input P3.3=INT1 P3.2=INT0
P3m1 = &B_0000_0000 : P3m0 = &B_0000_0000 '
P3pu = &B_0000_1100 ' 1: pull-up resistor
On Int0 Int0_int 'Initialise the INT0 Interrupt
'Priority Set Int0 'set INT0 to the highest priority level (INT1 has by default the highest prio)
'It0 = 0 ' Enable INT0 rising and falling interrupt
It0 = 1 ' Enable INT0 falling edge interrupt
Enable Int0 'enable the interrupt
Test_out = 1
For Temp = 0 To 9
My_led = 1
Waitms 50
My_led = 0
Waitms 50
Test_out = 0
Test_out = 1
Waitms 90
Test_out = 0
Waitms 90
Int0_int:
Incr Temp
If Temp > 5 Then
My_led = 1
Waitms 50
My_led = 0
Temp = 0
