У кого есть библиотека на Noikia3310 lcd? Поделитесь.
Noikia3310 lcd
Поделиться22007-03-14 21:07:46
Nokia 3310 display library+tool
The Nokia 3310 display is a cheap and widely available black dot matrix display with 504 dots arranged as 6 rows * 14 columns (or 48*84 pixels).
It is supplied by 2.7 - 3.3 V and only requires an external capacitor for the lcd voltage generation.
Included in this .zip file are:
2 library files for the BASCOM-AVR compiler
1 example main program file
1 MS Excel document with a simple character generator
1 Philips datasheet for the PCD8544 controller
2 photos of the code used in a real application.
Поделиться32007-04-10 22:14:54
http://www.avrfreaks.net/index.php?module=Freaks Files&func=viewFile&id=2280&showinfo=1
3310 Library file version 2.0 - with added bmp support [329.91 KB] (Apr 9, 2007)
Поделиться42007-04-29 22:28:23
Появилось обновление - http://www.avrfreaks.net/index.php?module=Freaks Academy&func=viewItem&item_id=887&item_type=project
3310 Slave board schematics and pcb layout [83.41 KB]
Поделиться52007-05-08 17:25:00
3310 master and slave boards schematics, pcb and photos
http://www.avrfreaks.net/index.php?module=Freaks Files&func=viewFile&id=2328&showinfo=1
