Доброе время суток всем! Форумы просмотрел что попалось попробовал и все же не могу сделать. А нужно для максимального сбережения засыпать на 30сек - 5мин. Готовый код отлично работает на "собаке" .
$regfile = "m88def.dat" ' Нужно для 48\88\328 $crystal = 8000000 $baud = 19200 $hwstack = 40 $swstack = 20 $framesize = 40 $prog &HFF , &H62 , &HDF , &HFF ' generated. Take care that the chip supports all fuse bytes. Prr = &B11101010 Acsr = &B10010001 Declare Sub R_register(byval Command As Byte , Byval C_bytes As Byte) Declare Sub W_register(byval C_bytes As Byte) '=== Constante === 'Define nRF24L01 interrupt flag's Const Idle_int = &H00 'Idle, no interrupt pending Const Max_rt = &H10 'Max #of Tx Retrans Interrupt Const Tx_ds = &H20 'Tx Data Sent Interrupt Const Rx_dr = &H40 'Rx Data Received 'SPI(nRF24L01) commands Const Read_reg = &H00 'Define Read Command To Register Const Write_reg = &H20 'Define Write Command To Register Const Rd_rx_pload = &H61 'Define Rx Payload Register Address Const Wr_tx_pload = &HA0 'Define Tx Payload Register Address Const Flush_tx = &HE1 'Define Flush Tx Register Command Const Flush_rx = &HE2 'Define Flush Rx Register Command Const Reuse_tx_pl = &HE3 'Define Reuse Tx Payload Register Command Const Nop_comm = &HFF 'Define No Operation , Might Be Used To Read Status Register 'SPI(nRF24L01) registers(addresses) Const Config_nrf = &H00 'Config' register address Const En_aa = &H01 'Enable Auto Acknowledgment' register address Const En_rxaddr = &H02 'Enabled RX addresses' register address Const Setup_aw = &H03 'Setup address width' register address Const Setup_retr = &H04 'Setup Auto. Retrans' register address Const Rf_ch = &H05 'RF channel' register address Const Rf_setup = &H06 'RF setup' register address Const Status = &H07 'Status' register address Const Observe_tx = &H08 'Observe TX' register address Const Cd = &H09 'Carrier Detect' register address Const Rx_addr_p0 = &H0A 'RX address pipe0' register address Const Rx_addr_p1 = &H0B 'RX address pipe1' register address Const Rx_addr_p2 = &H0C 'RX address pipe2' register address Const Rx_addr_p3 = &H0D 'RX address pipe3' register address Const Rx_addr_p4 = &H0E 'RX address pipe4' register address Const Rx_addr_p5 = &H0F 'RX address pipe5' register address Const Tx_addr = &H10 'TX address' register address Const Rx_pw_p0 = &H11 'RX payload width, pipe0' register address Const Rx_pw_p1 = &H12 'RX payload width, pipe1' register address Const Rx_pw_p2 = &H13 'RX payload width, pipe2' register address Const Rx_pw_p3 = &H14 'RX payload width, pipe3' register address Const Rx_pw_p4 = &H15 'RX payload width, pipe4' register address Const Rx_pw_p5 = &H16 'RX payload width, pipe5' register address Const Fifo_status = &H17 'FIFO Status Register' register address Dim D_bytes(33) As Byte , B_bytes(33) As Byte 'Dim the bytes use for SPI, D_bytes = outgoing B_bytes = Incoming Dim Temp As Byte , W As Word Dim Packet_count As Byte Dim Term As Word , Term_t As Word , T As Byte , Tt As Dword Dim Ubat As Word Dim Ux As Dword Dim Ubat_(2) As Byte At Ubat Overlay Dim Ter As Integer Dim Term_(2) As Byte At Ter Overlay Config Portd.5 = Output : U_24l01 Alias Portd.5 : Set U_24l01 '=== Config hardware === Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 16 , Noss = 1 'Software SPI is NOT working with the nRF24L01, use hardware SPI only, but the SS pin must be controlled by our self Config Pind.7 = Output 'CE pin is output Config Pinb.2 = Output 'SS pin is output Config Pind.6 = Input 'IRQ pin is input Ce Alias Portd.7 Ss Alias Portb.2 Irq Alias Pind.6 Config Portc.3 = Output : U_term Alias Portc.3 Spiinit 'init the spi pins Set Ce Waitms 10 'Wait a moment until all hardware is stable Reset Ce 'Set CE pin low Reset Ss 'Set SS pin low (CSN pin) D_bytes(1) = Flush_tx 'Flush the TX_fifo buffer Call W_register(1) D_bytes(1) = Write_reg + Status 'Reset the IRQ bits D_bytes(2) = &B00110000 Call W_register(2) Do Set U_term 'включаем датчик температуры Config Adc = Single , Prescaler = 128 , Reference = Internal Start Adc Term = Getadc(2) For T = 1 To 30 'Цикл измерения температуры Term = Getadc(2) Term_t = Term_t + Term Next Reset U_term Term = Term_t / 30 Ux = Term * 1059 Tt = Ux / 1000 Term = Tt Ter = Term - 500 Config Adc = Single , Prescaler = 128 , Reference = Avcc 'конфигурация АЦП Ubat = Getadc(14) 'Ux = 112640 / Ubat Ux = 117000 / Ubat 'Ux = 1126.4 / Ubat Ubat = Ux Config Adc = Single , Prescaler = 128 , Reference = Internal 'переключаем опорку, что бы конденсатор на Aref успел разрядиться Stop Adc Gosub Setup_tx 'Setup the nrf24l01 for TX D_bytes(1) = Wr_tx_pload 'Put 5 bytes in the TX pload buffer D_bytes(2) = Ter 'Байт 2 D_bytes(3) = Term_(1) 'Байт 3 D_bytes(4) = Term_(2) 'Байт 4 D_bytes(5) = Ubat D_bytes(6) = 1'Packet_count 'Byte 5 Call W_register(6) 'Write 6 bytes to register Waitms 2 Set Ce 'Set CE for a short moment to transmit the fifo buffer Waitms 1 ' Reset Ce ' Waitms 100 'Some delay to read the output on the terminal, line can be removed for max. speed W = 0 'Counter for time out Config Watchdog =8192 Start Watchdog Reset U_24l01 Reset U_term Portd = 0 : Portc = 0 : Portb = 0 Adcsr = &B00010000 Powerdown 'Спящий режим 8сек. Loop '=== Sub routines === Sub W_register(byval C_bytes As Byte) 'Write register with SPI Reset Ss 'Manual control SS pin, set SS low before shifting out the bytes Spiout D_bytes(1) , C_bytes 'Shiftout the data bytes trough SPI , C_bytes is the amount bytes to be written Set Ss 'Set SS high End Sub Sub R_register(byval Command As Byte , Byval C_bytes As Byte) As Byte 'C_bytes = Count_bytes, number off bytes to be read Reset Ss 'Manual controle SS pin, set low before shifting in/out the bytes Spiout Command , 1 'First shiftout the register to be read Spiin B_bytes(1) , C_bytes 'Read back the bytes from SPI sended by nRF20L01 Set Ss 'Set SS back to high level End Sub Setup_tx: 'Setup for TX D_bytes(1) = Write_reg + Tx_addr 'TX adress D_bytes(2) = &H34 D_bytes(3) = &H43 D_bytes(4) = &H10 D_bytes(5) = &H10 D_bytes(6) = &H01 Call W_register(6) D_bytes(1) = Write_reg + Rx_addr_p0 'RX adress for pipe0 D_bytes(2) = &H34 D_bytes(3) = &H43 D_bytes(4) = &H10 D_bytes(5) = &H10 D_bytes(6) = &H01 Call W_register(6) D_bytes(1) = Write_reg + En_aa 'Enable auto ACK for pipe0 D_bytes(2) = &H01 Call W_register(2) D_bytes(1) = Write_reg + En_rxaddr 'Enable RX adress for pipe0 D_bytes(2) = &H01 Call W_register(2) D_bytes(1) = Write_reg + Rf_ch 'Set RF channel D_bytes(2) = 40 Call W_register(2) D_bytes(1) = Write_reg + Rf_setup 'Setup RF-> Output power 0dbm, datarate 2Mbps and LNA gain on D_bytes(2) = &H06 Call W_register(2) D_bytes(1) = Write_reg + Config_nrf 'Setup CONFIG-> PRX=0(TX_device), PWR_UP=1, CRC 2bytes, Enable CRC D_bytes(2) = &H0E Call W_register(2) Return
Отредактировано qewin (2019-04-24 18:00:56)
. Хотя волтаж батарейки все правильно.
, получается эффект заторможенности но глюк не пропадает .
. Александр отправил в личку.
