Компилирую в 2079
Не видит изменение входа
$regfile = "xm128a4udef.dat" '$crystal = 32000000 '32MHz $hwstack = 64 $swstack = 40 $framesize = 40 $lib "xmega.lib" $external _xmegafix_clear $external _xmegafix_rol_r1014 Config Osc = Enabled , 32mhzosc = Enabled 'We use internal 32MHz Config Sysclock = 32mhz , Prescalea = 1 , Prescalebc = 1_1 'Internal 32MHz, no prescaler Config Porte.1 = Output Porte.1 = 1 On Porte_int0 Port_e_int0__isr Enable Porte_int0 , Lo Enable Interrupts Config Pine.0 = Input Config Xpin = Porte.0 , Outpull = Pullup , Sense = Falling Porte_int0mask = &B00000001 Do Loop Port_e_int0__isr: Toggle Porte.1 Waitms 500 Return
Отредактировано Menen (2016-04-27 16:00:40)
