'============ПЕРЕМЕННЫЕ И ПОРТЫ================================================ Config Pinb.2 = Input ' если 0 то идет зарядка Config Pind.2 = Output : Portd.2 = 1 : Config Pind.2 = Input : Tsop1 Alias Pind.2 Config Pind.3 = Input : Tsop2 Alias Pind.3 Config Pinb.0 = Output : Led_ir_back Alias Portb.0 Config Pinb.1 = Output : Led_ir_right Alias Portb.1 Config Pinb.2 = Output : Led_ir_left Alias Portb.3 Config Pinc.4 = Output : Led_r1 Alias Portc.4 Config Pinc.5 = Output : Led_g1 Alias Portc.5 Config Pinc.6 = Output : Led_r2 Alias Portc.6 Config Pinc.7 = Output : Led_g2 Alias Portc.7 Config Pind.6 = Output : All_ir_led Alias Portd.6 Config Pind.7 = Output : Portd.7 = 0 : Spik Alias Portd.7 Config Timer1 = Pwm , Pwm = 8 , Prescale = 1 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down Config Pinc.2 = Output : Drl Alias Portc.2 : Config Pind.4 = Output Config Pinc.3 = Output : Drr Alias Portc.3 : Config Pind.5 = Output '============ ПОДПРОГРАММЫ=================================================== Declare Sub Влево(byval speed As Byte) Declare Sub Вправо(byval speed As Byte) Declare Sub Прямо(byval speed As Byte) Declare Sub Назад(byval speed As Byte) Declare Sub Стоп() Declare Function Запрос_маяка(byval Adress As Byte , Byval Beacon_power As Byte) As Byte Declare Function Binari_power(byval Dec_power As Byte) As Byte
