'----------------------- Мультимедиа-Клавиатура HID на USB ---------------------
' Bascom -avr V.2.0.4.0
' Rubashka Vasiliy
' Ukraine
' 2011
' Combined by MrShilov © 2012
'$prog &HFF , &HFF , &HD9 , &HFF 'Take care that the chip supports all fuse bytes.
$noramclear
$swstack = 40
$framesize = 50
$regfile = "m8def.dat" 'ATMEGA8-16PU
$crystal = 12000000 'Кварц - был 15МГц, заменен на 12МГц !!!!!!!!!!!!!!!!
'Include the software USB library - NEW
$lib "swusb.lbx"
$external _swusb
Declare Sub Usb_reset()
Declare Sub Usb_processsetup(txstate As Byte)
Declare Sub Usb_send(txstate As Byte , Byval Count As Byte)
Declare Sub Usb_senddescriptor(txstate As Byte , Maxlen As Byte)
'*************************** Конфигурация USB **********************************
'Set the following parameters to match your hardware configuration and USB
'device parameters.
'******************************* USB Connections *******************************
'Define the AVR port that the two USB pins are connected to
_usb_port Alias Portd
_usb_pin Alias Pind
_usb_ddr Alias Ddrd
'Define the D+ and D- pins. (put D+ on an interrupt pin)
Const _usb_dplus = 2
Const _usb_dminus = 4
' 0,1| | | | ATMEGA 8 |
' --- | +-----+---[1k5]-+ +--\/--+ |
' USB --- | | +---[10k]---*--|1 28| |
' | | CAPS | +--|<|--[300]---+--|2 27| |
' /---\ | | NUM | *--|<|--[300]---+--|3 26| |
' | VCC|-1-+--+ +------+-+-------[68 ]---+--|4 25| |
' \ | | | LOCK | *--|<|--[300]---+--|5 24| |
' |D-|-2-+--*-+------*-+-------[68 ]---+--|6 23| |
' | | | | | | +--+--|7 22|--------+-+
' |D+|-3-+--+-*-L<|----*------------+--+--|8 21| | |
' / | | | | +----------+--+--|9 20|--------* |
' | GND|-4-* +---L<|----* | === +--+--+--|10 19|------+ | |
' \---/ | 2x3,6v | +-12MHz-+ | | |11 18|----+ | | |
' | | === | | |12 17|--+ | | | |
' +-------------*--|<|--[300]+--+--|13 16| | | | | |
' |STATUS | | |14 15| | | | | |
' | |0,1 +|22,0 | | | | | |
' === V V V V V V
' R M M S V G
' E O I C C N
' S S S K C D
'Configure the pins as inputs
Ddrb = &B11110011 'направление линий порта B: 1 - на вывод
Portb = &B00011111 'исходное состояние линий B: 00000000
Ddrc = &B00000000 'направление линий порта C: 1 - на вывод
Portc = &B11111111 'исходное состояние линий C: 00000000
Ddrd = &B11101011 'направление линий порта D: 1 - на вывод
Portd = &B00000000 'исходное состояние линий D: 00000000
Config Pinb.0 = Input ' энкодер
Config Pinb.1 = Input
Portb = 255
Config Rc5 = Pind.3
Config Pind.3 = Input
Config Portc.1 = Output
Config Portd.1 = Output
Portd.1 = 1 '
'disable pullups
_usb_port._usb_dplus = 0
_usb_port._usb_dminus = 0
'************************* USB константы конфигурации **************************
'Использовать EEPROM или FLASH для хранения USB дескрипторов
'1 = EEPROM, 0 = FLASH. Использование EEPROM немного уменьшит размер кода.
Const _usb_use_eeprom = 0
'Don't wait for sent packets to be ACK'd by the host before marking the
'transmission as complete. This option breaks the USB spec but improves
'throughput with faster polling speeds.
'This may cause reliability issues. Should leave set to 0 to be safe.
Const _usb_assume_ack = 0
'***************************** Дескриптор устройства****************************
'USB Vendor ID and Product ID (Assigned by USB-IF)
Const _usb_vid = &HBBBB
Const _usb_pid = &HEF33
'USB Device Release Number (BCD)
Const _usb_devrel = &H0001
'USB Release Spec (BCD)
Const _usb_spec = &H0110
'USB Device Class, subclass, and protocol (assigned by USB-IF).
'&h00 = Class defined by interface. (HID is defined in the interface)
'&hFF = Vendor-defined class (You must write your own PC driver)
'See http://www.usb.org/developers/defined_class for more information
Const _usb_devclass = 0
Const _usb_devsubclass = 0
Const _usb_devprot = 0
'These are _indexes_ to UNICODE string descriptors for the manufacturer,
'product name, and serial number. 0 means there is no descriptor.
Const _usb_imanufacturer = 1
Const _usb_iproduct = 2
Const _usb_iserial = 0
'Количество конфигураций для этого устройства. Не изменяйте это если,
'вы не знаете то, что Вы делаете! Обычно равно 1
Const _usb_numconfigs = 1
'***************************** Конфигурация дискиптора *************************
'Количество интерфейсов для этого устройства (Обычно 1)
'Const _usb_numifaces = 1
Const _usb_numifaces = 2 'Теперь у нас 2 интерфейса !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'Номер конфигурации (не редактировать!)
Const _usb_confignum = 1
'Индекс дескриптора строки УНИКОДА, который описывает эту конфигурацию (0 - отсутствует)
'Const _usb_iconfig = 2
Const _usb_iconfig = 0 'Не требуется !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'&H80 = Устройство питается от шины USB.
'&HC0 = Устройство имеет свой источник питания.
'Const _usb_powered = &H80
Const _usb_powered = &HA0 'Питание от шины USB с возможностью "будить" компьютер !!!!!!!!!
'Потребляемый устройством ток * 2mA (500mA max)
Const _usb_maxpower = 150 '50 * 2mA = 100mA
'**************************** Дескрипторы интерфейса ***************************
'Число интерфейсов для этого устройства (1 или 2)
'Const _usb_ifaces = 1
Const _usb_ifaces = 2 'Теперь у нас 2 интерфейса !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'Номер интерфейса
Const _usb_ifaceaddr = 0
Const _usb_ifaceaddr1 = 1 'Индекс адреса второго интерфейса ******************************
'Альтернативный индекс
Const _usb_alternate = 0
Const _usb_alternate1 = 0 'У второго интерфейса тот же альтернативный адрес **************
'Количество конечных точек для этого интерфейса (исключая нулевую)
'Const _usb_ifaceendpoints = 2
Const _usb_ifaceendpoints = 1 'Одна точка для первого интерфейса !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Const _usb_ifaceendpoints1 = 1 'Одна точка для второго интерфейса *****************************
'USB класс интерфейса, подкласс, и протокол (назначенное USB-IF).
'&h00 = RESERVED
' Other values are USB interface device class. (such as HID)
Const _usb_ifclass = 3
Const _usb_ifclass1 = 3 'Второй интерфейс тоже по прерыванию ***************************
'Const _usb_ifsubclass = 0
Const _usb_ifsubclass = 1 'Для клавиатуры субкласс 1 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Const _usb_ifsubclass1 = 0 'Для мультимедиа субкласс 0 ************************************
'Const _usb_ifprotocol = 0
Const _usb_ifprotocol = 1 'Для клавиатуры протокол 1
Const _usb_ifprotocol1 = 0 'Для мультимедиа протокол 0
'Индекс в дескрипторе строки УНИКОДА для этого интерфейса (0 - отсутствует)
Const _usb_iiface = 0
Const _usb_iiface1 = 0 'Для мультимедиа тоже отсутствует ******************************
'*************************** Дополнительный HID дескриптор *********************
'HID класс, устройств являются вещами подобно клавиатуре, мыши, джойстику.
'See http://www.usb.org/developers/hidpage/ for the specification,
'tools, and resources.
'Учтите, что для устройства HID, класс устройства, подкласс, и протокол
'должен быть 0. Класс интерфейса должен быть 3 (HID).
'Подкласс Интерфейса и протокола должны быть 0 если Вы не делаете
'клавиатурой или мышь, которые поддерживают встроенный протокол.
'Смотрите страницы 8 и 9 спецификации HID 1.11 PDF.
'Число HID дескриптора (EXCLUDING report and physical)
'Если Вы не делаете устройство HID, тогда установите эту константу на 0
'Const _usb_hids = 1
Const _usb_hids = 2 'Общее количество HID теперь 2 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'BCD HID releasenumber. Current spec is 1.11
Const _usb_hid_release = &H0111
'Country code from page 23 of the HID 1.11 specifications.
'Usually the country code is 0 unless you are making a keyboard.
Const _usb_hid_country = 0
' Номер сообщения и физических дескрипторов для этого HID
' Должно быть в 1! Все HID устройства иметь по крайней мере 1 дескриптор сообщения.
Const _usb_hid_numdescriptors = 1
'Use a software tool to create the report descriptor and $INCLUDE it.
'*************************** Дескриптор конечной точки *************************
'Конечная точка 0 не включается здесь. Эти - только для других
'конечных точек.
'Примечание: HID устройства требуют 1 прерывание В конечной точке
'Адрес дополнительных конечных точек (Должно быть > 0. сделать комментарием, если не требуется)
Const _usb_endp2addr = 1
Const _usb_endp3addr = 2
'Правильные типы - 0 для управления или 3 для прерывания
Const _usb_endp2type = 3
Const _usb_endp3type = 3
'Направление: 0=Out (от компа), 1=In (в комп). Проигнорированно управляющими конечными точками
Const _usb_endp2direction = 1
'Const _usb_endp3direction = 0
Const _usb_endp3direction = 1 'Теперь и вторая точка тоже из МК в ПК !!!!!!!!!!!!!!!!!!!!!!!!
' Интервал опроса (мс) для конечных точек прерывания.
' Проигнорированно управляющими конечными точками
' (Должно быть не менее 10)
Const _usb_endp2interval = 10
Const _usb_endp3interval = 10
'The includes need to go right here--between the configuration constants above
'and the start of the program below. The includes will automatically calculate
'constants based on the above configuration, dimension required variables, and
'allocate transmit and receive buffers. Nothing inside the includes file needs
'to be modified.
$include "Const_swusb-includes.bas"
'**************************** USB Interrupt And Init ***************************
'Инициализация всех переменных, флагов, и бит синхронизации
Call Usb_reset()
Const _usb_intf = Intf0
Config Int0 = Rising
On Int0 Usb_isr Nosave
Enable Int0
Enable Interrupts 'Разрешить все прерывания
'*************************** Завершение концигурации USB ***********************
Led Alias Portc.1
Dim Resetcounter As Word
Dim Idlemode As Byte
Dim Flaginputmsg As Byte 'Флаг срабатывания таймера
Dim Keymsg(8) As Byte 'Передаваемый репорт (8 байт)
Dim Key(35) As Byte 'Массив состояния клавиш
Dim Lastkey(35) As Byte 'Массив предыдущего состояния клавиш
Dim K As Byte 'Счётчик цикла сканирования клавиш
Dim Paus As Byte 'Пауза между передаваемыми символами
Dim B1 As Byte
Dim Address As Byte , Command As Byte
Paus = 50
'Portc = 1
'Portb.5 = 1
'Настроим таймер
Config Timer1 = Timer , Prescale = 256
On Timer1 Setflag
Enable Timer1
'Помигаем светодиодом статуса - контроллер стартовал
Led = 1
Led = 0
Waitms 300
Led = 1
Led = 0
Waitms 300
Led = 1
Led = 0
' Формат передаваемого репорта - usb_tx_buffer:
_usb_tx_buffer2(2) = 0 ' modifier - комбинация из 8-ми модификаций (левые и правые Ctrl, Alt, Shift, Win)
_usb_tx_buffer2(3) = 0 ' reserved - резерв
_usb_tx_buffer2(4) = 0 ' keycode 0 - код клавиши 0
_usb_tx_buffer2(5) = 0 ' keycode 1 - код клавиши 1
_usb_tx_buffer2(6) = 0 ' keycode 2 - код клавиши 2
_usb_tx_buffer2(7) = 0 ' keycode 3 - код клавиши 3
_usb_tx_buffer2(8) = 0 ' keycode 4 - код клавиши 4
_usb_tx_buffer2(9) = 0 ' keycode 5 - код клавиши 5
' modifier
' bit0 LEFT CTRL (1)
' bit1 LEFT SHIFT (2)
' bit2 LEFT ALT (4)
' bit3 LEFT WIN (8)
' bit4 RIGHT CTRL (16)
' bit5 RIGHT SHIFT (32)
' bit6 RIGHT ALT (64)
' bit7 RIGHT WIN (128)
' CTRL + ALT + DEL
' Эту комбинацию нужно передать так: &H05, &H00, &H4С, &H00, &H00, &H00, &H00, &H00 = 5[Ctrl(1) + Alt(4)], 0, 76, 0, 0, 0, 0, 0
' В первый байт попадает сумма модификаций клавиш (левые и правые Ctrl, Alt, Shift, Win)
'******************************* Основной цикл *********************************
Resetcounter = 0
'Флаг сброса
While _usb_pin._usb_dminus = 0
Incr Resetcounter
If Resetcounter = 1000 Then
Call Usb_reset()
Wend
'Флаг полученных данных
If _usb_status._usb_rxc = 1 Then
If _usb_status._usb_setup = 1 Then
'Обработка пакет/управление сообщения установки
Call Usb_processsetup(_usb_tx_status)
'Состояние конечных точек изменилось, поэтому управление светодиодами ******************************************
'перенесем в подпрограмму обработки запросов "Usb_processsetup" ******************************************
'Elseif _usb_status._usb_endp1 = 1 Then ' Пришёл пакет данных с компа !!!!!!!!!!!!!!!!!!!!!!!
'Portd.0 = _usb_rx_buffer(2).0 'Состояние светодиодного индикатора CAPS !!!!!!!!!!!!!!!!!!!!!!!
'Portd.1 = _usb_rx_buffer(2).1 'Состояние светодиодного индикатора NUM !!!!!!!!!!!!!!!!!!!!!!!
'Portd.3 = _usb_rx_buffer(2).2 'Состояние светодиодного индикатора LOCK !!!!!!!!!!!!!!!!!!!!!!!
'Восстановление бита RXC и установка бита RTR (готовность получить новый пакет)
_usb_status._usb_rtr = 1
_usb_status._usb_rxc = 0
Getrc5(address , Command)
If Address = 0 Then
Command = Command And &B01111111 'clear the toggle bit toggle bit is bit 7. Extended RC5 bit is in bit 6
If Flaginputmsg = 1 Then
B1 = Encoder(pinb.2 , Pinb.1 , Links , Rechts , 0) ' опрос энкодера
'*************************** СКАНИРУЕМ КЛАВИАТУРУ ******************************
Key(1) = Pinc.2
Key(2) = Pinc.3
Key(3) = Pinc.4
Key(4) = Pinc.5
'************************ команды RC5 ****************************
If Command = 38 Then ' restart USB
Led = 1
Ddrd.1 = 0
Portd.1 = 0
Waitms 1000
Waitms 1000
Waitms 1000
Ddrd.1 = 1
Portd.1 = 1
Led = 0
If Command = 15 Then ' Esc
Led = 1
If _usb_tx_status._usb_txc = 1 Then
_usb_tx_buffer2(4) = 29
Call Usb_send(_usb_tx_status2 , 8) ' Сообщение в компьютер
Waitms Paus
_usb_tx_buffer2(2) = 0 ' Отжатие клавиш
Waitms Paus
Led = 0
If Command = 63 Then
Led = 1
If _usb_tx_status._usb_txc = 1 Then ' Volume-
_usb_tx_buffer3(2) = 1 ' Нажатие клавиш
_usb_tx_buffer3(3) = 234
_usb_tx_buffer3(4) = 0
Call Usb_send(_usb_tx_status3 , 3) ' Сообщение в компьютер
Waitms Paus
_usb_tx_buffer3(2) = 1 ' Отжатие клавиш
_usb_tx_buffer3(3) = 0
Waitms Paus
Led = 0
If Command = 56 Then
Led = 1
If _usb_tx_status._usb_txc = 1 Then ' Volume+
_usb_tx_buffer3(3) = 233
Waitms Paus
Waitms Paus
Led = 0
If Command = 55 Then
Led = 1
_usb_tx_buffer2(2) = 0 ' Пробел
_usb_tx_buffer2(4) = 44
Waitms Paus
Waitms Paus
Led = 0
If Command = 17 Then
Led = 1
_usb_tx_buffer2(2) = 0 ' влево
_usb_tx_buffer2(4) = 80
Waitms Paus
Waitms Paus
Led = 0
If Command = 16 Then
Led = 1
_usb_tx_buffer2(2) = 0 ' вправо
_usb_tx_buffer2(4) = 79
Waitms Paus
Waitms Paus
Led = 0
If Command = 32 Then
Led = 1
_usb_tx_buffer2(2) = 0 ' вверх
_usb_tx_buffer2(4) = 82
Waitms Paus
Waitms Paus
Led = 0
If Command = 33 Then
Led = 1
_usb_tx_buffer2(2) = 0 ' вниз
_usb_tx_buffer2(4) = 81
Waitms Paus
Waitms Paus
Led = 0
If Command = 59 Then
Led = 1
_usb_tx_buffer2(2) = 0 ' Энтер
_usb_tx_buffer2(4) = 40
Waitms Paus
Waitms Paus
Led = 0
If Command = 50 Then
Led = 1
If _usb_tx_status._usb_txc = 1 Then ' Stop
_usb_tx_buffer3(3) = 183
Waitms Paus
Waitms Paus
Led = 0
If Command = 43 Then
Led = 1
If _usb_tx_status._usb_txc = 1 Then ' Play/Pause
_usb_tx_buffer3(3) = 205
Waitms Paus
Waitms Paus
Led = 0
If Command = 13 Then
Led = 1
If _usb_tx_status._usb_txc = 1 Then ' Mute
_usb_tx_buffer3(3) = 226
Waitms Paus
Waitms Paus
Led = 0
If Command = 41 Then
Led = 1
If _usb_tx_status._usb_txc = 1 Then ' Next
_usb_tx_buffer3(3) = 181
Waitms Paus
Waitms Paus
Led = 0
If Command = 44 Then
Led = 1
If _usb_tx_status._usb_txc = 1 Then ' Prew
_usb_tx_buffer3(3) = 182
Waitms Paus
Waitms Paus
Led = 0
'*************** команды с клавиатуры ****************
If Key(2) = 0 Then
Led = 1
Waitms Paus
Waitms Paus
Led = 0
If Key(3) = 0 Then
Led = 1
Waitms Paus
Waitms Paus
Led = 0
'*************************** Конец основного цикла *****************************
'**************************** Энкодер ************************
Links: ' энкодер в лево
Led = 1
Waitms 30
Waitms 30
Led = 0
Rechts: ' энкодер в право
Led = 1
Waitms 30
Waitms 30
Led = 0
'************************ Посылка кода одной клавиши ***************************
'Send_u8:
' If Flaginputmsg = 0 Then
' If _usb_tx_status._usb_txc = 1 Then
' Led = 1
' _usb_tx_buffer2(4) = Keymsg(3)
' Call Usb_send(_usb_tx_status2 , 8) ' Сообщение в компьютер
' Led = 0
' End If
' End If
'Return
'**************** Дескрипторы, сохранённые в EEPROM или FLASH ******************
' Не изменять порядок дескрипторов!
#if _usb_use_eeprom = 1
$eeprom
#else
$data
#endif
'Дескрипторы устройства
_usb_devicedescriptor:
Data 18 , 18 , _usb_desc_device , _usb_specl , _usb_spech , _usb_devclass
Data _usb_devsubclass , _usb_devprot , 8 , _usb_vidl , _usb_vidh , _usb_pidl
Data _usb_pidh , _usb_devrell , _usb_devrelh , _usb_imanufacturer
Data _usb_iproduct , _usb_iserial , _usb_numconfigs
'Retrieving the configuration descriptor also gets all the interface and
'endpoint descriptors for that configuration. It is not possible to retrieve
'only an interface or only an endpoint descriptor. Consequently, this is a
'large transaction of variable size.
_usb_configdescriptor:
Data _usb_descr_total , 9 , _usb_desc_config , _usb_descr_totall
Data _usb_descr_totalh , _usb_numifaces , _usb_confignum , _usb_iconfig
Data _usb_powered , _usb_maxpower
'_usb_IFaceDescriptor
Data 9 , _usb_desc_iface , _usb_ifaceaddr , _usb_alternate
Data _usb_ifaceendpoints , _usb_ifclass , _usb_ifsubclass , _usb_ifprotocol
Data _usb_iiface
'#if _usb_hids > 0
'_usb_HIDDescriptor
Data _usb_hid_descr_len , _usb_desc_hid , _usb_hid_releasel , _usb_hid_releaseh
Data _usb_hid_country , _usb_hid_numdescriptors
'Next follows a list of bType and wLength bytes/words for each report and
'physical descriptor. There must be at least 1 report descriptor. In practice,
'There are usually 0 physical descriptors and only 1 report descriptor.
Data _usb_desc_report
Data 63 , 0 ' первое число должно быть таким же, как количество данных дескриптора HID - _usb_hid_reportdescriptor
'End of report/physical descriptor list
'#endif
'#if _usb_endpoints > 1
'_usb_EndpointDescriptor
Data 7 , _usb_desc_endpoint , _usb_endp2attr , _usb_endp2type , 8 , 0
Data _usb_endp2interval
'#endif
'_usb_IFaceDescriptor1 *************************************************************************************
Data 9 , _usb_desc_iface , _usb_ifaceaddr1 , _usb_alternate1 ' ***********
Data _usb_ifaceendpoints1 , _usb_ifclass1 , _usb_ifsubclass1 , _usb_ifprotocol1 ' ***********
Data _usb_iiface1 ' ***********
'_usb_HIDDescriptor1 *************************************************************************************
Data _usb_hid_descr_len , _usb_desc_hid , _usb_hid_releasel , _usb_hid_releaseh ' ***********
Data _usb_hid_country , _usb_hid_numdescriptors , _usb_desc_report ' ***********
Data 50 , 0 'Длина мультимедиа-репорта 50 байт ***********
'#if _usb_endpoints > 2
'Data 7 , _usb_desc_endpoint , _usb_endp3attr , _usb_endp3type , 8 , 0
Data 7 , _usb_desc_endpoint , _usb_endp3attr , _usb_endp3type , 3 , 0 'Для мультимедиа длина сообщения 3 байта !!!!!!!!!!!!!!!!
Data _usb_endp3interval
'#endif
'#if _usb_hids > 0
_usb_hid_reportdescriptor:
Data 63 'Количество данных дескриптора HID, установить такое же в _usb_desc_report
Data &H05 , &H01 ' USAGE_PAGE (Generic Desktop)
Data &H09 , &H06 ' USAGE (Keyboard)
Data &HA1 , &H01 ' COLLECTION (Application)
Data &H05 , &H07 ' USAGE_PAGE (Keyboard)
Data &H19 , &HE0 ' USAGE_MINIMUM (Keyboard LeftControl)
Data &H29 , &HE7 ' USAGE_MAXIMUM (Keyboard Right GUI)
Data &H15 , &H00 ' LOGICAL_MINIMUM (0)
Data &H25 , &H01 ' LOGICAL_MAXIMUM (1)
Data &H75 , &H01 ' REPORT_SIZE (1)
Data &H95 , &H08 ' REPORT_COUNT (8)
Data &H81 , &H02 ' INPUT (Data,Var,Abs) ** Modifier Byte **
Data &H95 , &H01 ' REPORT_COUNT (1)
Data &H75 , &H08 ' REPORT_SIZE (8)
Data &H81 , &H03 ' INPUT (Cnst,Var,Abs) ** Reserved Byte **
Data &H95 , &H05 ' REPORT_COUNT (5)
Data &H05 , &H08 ' USAGE_PAGE (LEDs)
Data &H19 , &H01 ' USAGE_MINIMUM (Num Lock)
Data &H29 , &H05 ' USAGE_MAXIMUM (Kana)
Data &H91 , &H02 ' OUTPUT (Data,Var,Abs) ** LED Report **
Data &H75 , &H03 ' REPORT_SIZE (3)
Data &H91 , &H03 ' OUTPUT (Cnst,Var,Abs) ** LED Report Padding **
Data &H95 , &H06 ' REPORT_COUNT (6) ** here we define the maximum number of simultaneous keystrokes we can detect **
Data &H25 , &H65 ' LOGICAL_MAXIMUM (101)
Data &H19 , &H00 ' USAGE_MINIMUM (Reserved (no event indicated))
Data &H29 , &H65 ' USAGE_MAXIMUM (Keyboard Application)
Data &H81 , &H00 ' INPUT (Data,Ary,Abs) ** Key arrays (6 bytes) **
Data &HC0 ' END_COLLECTION
_usb_hid_reportdescriptor1: ' ************
Data 50 ' ************
Data &H05 , &H0C 'Usage Page (Consumer Devices) ************
Data &H09 , &H01 'Usage (Consumer Control) * Мультимедиа клавиши ************
Data &HA1 , &H01 'Collection (Application) ************
Data &H85 , &H01 ' Report ID (1) ************
Data &H19 , &H00 ' Usage Minimum (Undefined) ************
Data &H2A , &H3C , &H02 ' Usage Maximum (reserved 0x023c) ************
Data &H15 , &H00 ' Logical Minimum (0) ************
Data &H26 , &H3C , &H02 ' Logical Maximum (572) ************
Data &H95 , &H01 ' Report Count (1) ************
Data &H75 , &H10 ' Report Size (16) ************
Data &H81 , &H00 ' Input (Data,Ary,Abs) ************
Data &HC0 'End Collection ************
Data &H05 , &H01 'Usage Page (Generic Desktop) ************
Data &H09 , &H80 'Usage (System Control) * Управление питанием ************
Data &H85 , &H02 ' Report ID (2) ************
Data &H19 , &H81 ' Usage Minimum (System Power Down) ************
Data &H29 , &H83 ' Usage Maximum (System Wake Up) ************
Data &H25 , &H01 ' Logical Maximum (1) ************
Data &H75 , &H01 ' Report Size (1) ************
Data &H95 , &H03 ' Report Count (3) ************
Data &H81 , &H02 ' Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) ************
Data &H95 , &H05 ' Report Count (5) ************
Data &H81 , &H01 ' Input (Cnst,Ary,Abs) ************
'#endif
'*****************************String descriptors********************************
' Yes, they MUST be written like "t","e","s","t". Doing so pads them with
' 0's. If you write it like "test," I promise you it won't work.
' Нужно писать так: "t","e","s","t".
' Если написать "test," - работать не будет
'Default language descriptor (index 0)
'Дескриптор языка по умолчанию (индекс 0)
_usb_langdescriptor:
Data 4 , 4 , _usb_desc_string , 09 , 04 '&h0409 = English
'Data 4 , 4 , _usb_desc_string , 19 , 04 '&h0419 = Русский
'Manufacturer Descriptor (unicode)
'Дескриптор изготовителя (unicode)
_usb_mandescriptor:
' Radan & MrShilov
Data 34 , 34 , _usb_desc_string
Data &H52 , &H00 , &H61 , &H00 , &H64 , &H00 , &H61 , &H00 , &H6E , &H00
Data &H20 , &H00 , &H26 , &H00 , &H20 , &H00 , &H4D , &H00 , &H72 , &H00
Data &H53 , &H00 , &H68 , &H00 , &H69 , &H00 , &H6C , &H00 , &H6F , &H00
Data &H76 , &H00 , &H00 , 0
'Product Descriptor (unicode)
'Дескриптор продукта (unicode)
_usb_proddescriptor:
'Атомная клавиатура виндуксоида v.2
Data 70 , 70 , _usb_desc_string
Data &H10 , &H04 , &H42 , &H04 , &H3E , &H04 , &H3C , &H04 , &H3D , &H04
Data &H30 , &H04 , &H4F , &H04 , &H20 , &H00 , &H3A , &H04 , &H3B , &H04
Data &H30 , &H04 , &H32 , &H04 , &H38 , &H04 , &H30 , &H04 , &H42 , &H04
Data &H43 , &H04 , &H40 , &H04 , &H30 , &H04 , &H20 , &H00 , &H32 , &H04
Data &H38 , &H04 , &H3D , &H04 , &H34 , &H04 , &H43 , &H04 , &H3A , &H04
Data &H41 , &H04 , &H3E , &H04 , &H38 , &H04 , &H34 , &H04 , &H30 , &H04
Data &H20 , &H00 , &H76 , &H00 , &H2E , &H00 , &H32 , &H00 , &H00 , 0
'Дескриптор номера
_usb_numdescriptor:
Data "2" , 0 , 0
'************************* Subroutines - Подпрограммы ***************************
Senddescriptor = 0
'Control transfers reset the sync bits like so
Txstate = _usb_setup_sync
'These are the standard device, interface, and endpoint requests that the
'USB spec requires that we support.
Select Case _usb_rx_buffer(2)
'Стандартные запросы устройств
Case &B10000000:
Select Case _usb_rx_buffer(3)
' Case _usb_req_get_status: ' 00 - Определение состояния устройства
Case _usb_req_get_descriptor:
Select Case _usb_rx_buffer(5)
Case _usb_desc_device:
'Отправка дескриптора устроства
Readeeprom _usb_eepromaddrl , _usb_devicedescriptor
#else
Restore _usb_devicedescriptor
#endif
Senddescriptor = 1
Case _usb_desc_config:
'Отправка дескриптора конфигурации
Readeeprom _usb_eepromaddrl , _usb_configdescriptor
#else
Restore _usb_configdescriptor
#endif
Senddescriptor = 1
Case _usb_desc_string:
Select Case _usb_rx_buffer(4)
Case 0:
'Отправка дескриптора выбраного языка
Readeeprom _usb_eepromaddrl , _usb_langdescriptor
#else
Restore _usb_langdescriptor
#endif
Senddescriptor = 1
Case 1:
'Отправка дескриптора изготовителя
Readeeprom _usb_eepromaddrl , _usb_mandescriptor
#else
Restore _usb_mandescriptor
#endif
Senddescriptor = 1
Case 2:
'Отправка дескриптора продукта
Readeeprom _usb_eepromaddrl , _usb_proddescriptor
#else
Restore _usb_proddescriptor
#endif
Senddescriptor = 1
Case 3:
'Отправка дескриптора номера
Readeeprom _usb_eepromaddrl , _usb_numdescriptor
#else
Restore _usb_numdescriptor
#endif
Senddescriptor = 1
' CASE _usb_REQ_GET_CONFIG:
Case &B00000000:
' CASE _usb_REQ_CLEAR_FEATURE: ' 01 Сброс устройства
' CASE _usb_REQ_SET_FEATURE: ' 03 Установить свойство
Case _usb_req_set_address:
'USB status reporting for control writes
Call Usb_send(txstate , 0)
While Txstate._usb_txc = 0 : Wend
'We are now addressed.
_usb_deviceid = _usb_rx_buffer(4)
' CASE _usb_REQ_SET_DESCRIPTOR:
Case _usb_req_set_config:
'Have to do status reporting
'Стандартные запросы интерфейса
Case &B10000001:
' CASE _usb_REQ_GET_STATUS:
' CASE _usb_REQ_GET_IFACE:
'_usb_rx_buffer(4) Индекс дескриптора и (5) его тип
Case _usb_desc_report:
Readeeprom _usb_eepromaddrl , _usb_hid_reportdescriptor
#else
'Restore _usb_hid_reportdescriptor
If _usb_rx_buffer(6) = 0 Then Restore _usb_hid_reportdescriptor 'Первый интерфейс ****************
If _usb_rx_buffer(6) = 1 Then Restore _usb_hid_reportdescriptor1 'Второй интерфейс ****************
#endif
Senddescriptor = 1
' CASE _usb_DESC_PHYSICAL
' CASE _USB_DESC_HID
Case &B00100001:
'Class specific SET requests
'Управление состоянием светодиодов NumLock, CapsLock и ScrollLock ****************************************************
Case _usb_req_set_report: '*********************************************************************
_usb_status._usb_rxc = 0 '*********************************************************************
_usb_status._usb_rtr = 1 '*********************************************************************
_usb_status2._usb_ignore = 0 '*********************************************************************
'Do status reporting '********************************************************************
Call Usb_send(txstate , 0) '********************************************************************
Do '********************************************************************
Loop Until _usb_status._usb_rxc = 1 '*******************************************************************
Portd.0 = _usb_rx_buffer(2).0 'Состояние светодиодного индикатора NumLock ***********************
' Portd.1 = _usb_rx_buffer(2).1 'Состояние светодиодного индикатора CapsLock ***********************
Portd.3 = _usb_rx_buffer(2).2 'Состояние светодиодного индикатора ScrollLock ***********************
Case _usb_req_set_idle:
Idlemode = 1
'CASE _usb_REQ_SET_PROTOCOL:
If Senddescriptor = 1 Then
Call Usb_senddescriptor(txstate , _usb_rx_buffer(8))
'Break the descriptor into packets and send to TxState
Local Size As Byte
Local I As Byte
Local J As Byte
Local Timeout As Word
'EEPROM access is a little funky. The size has already been fetched
'and stored in _usb_EEPROMADDRL, and the address of the descriptor
'is now in the EEAR register pair.
Size = _usb_eepromaddrl
'Fetch the location of the descriptor and use it as an address pointer
push R24
in R24, EEARL
sts {_USB_EEPROMADDRL}, R24
in R24, eearH
sts {_USB_EEPROMADDRH}, R24
pop R24
#else
Read Size
#endif
If Maxlen < Size Then Size = Maxlen
I = 2
For J = 1 To Size
Incr I
Incr _usb_eepromaddr
Readeeprom Txstate(i) , _usb_eepromaddr
#else
Read Txstate(i)
#endif
If I = 10 Or J = Size Then
I = I - 2
Call Usb_send(txstate , I)
Timeout = 0
'To prevent an infinite loop, check for reset here
Incr Timeout
If Timeout = 1000 Then '
Call Usb_reset()
Exit Sub
Wend
Wend
I = 2
'Calculates and adds the CRC16,adds the DATAx PID,
'and signals to the ISR that the data is ready to be sent.
'"Count" is the DATA payload size. Range is 0 to 8. Do not exceed 8!
'Reset all the flags except TxSync and RxSync
Txstate = Txstate And _usb_syncmask
'Calculate the 16-bit CRC
_usb_crc = 0
If Count <> 0 Then
_usb_crc = Crc16uni(txstate(3) , Count , &HFFFF , &H8005 , 1 , 1)
Toggle _usb_crc
'Bytes to transmit will be PID + DATA payload + CRC16
Count = Count + 3
Txstate = Txstate + Count
Txstate(count) = Low(_usb_crc)
Incr Count
Txstate(count) = High(_usb_crc)
'Add the appropriate DATAx PID
Txstate(2) = _usb_pid_data1
If Txstate._usb_txsync = 0 Then
Txstate(2) = _usb_pid_data0
'The last step is to signal that the packet is Ready To Transmit
Txstate._usb_rtt = 1
Sub Usb_reset()
'Reset the receive flags
'Reset the transmit flags
_usb_tx_status = _usb_endp_init
#if Varexist( "_usb_Endp2Addr")
_usb_tx_status2 = _usb_endp_init
#endif
#if Varexist( "_usb_Endp3Addr")
_usb_tx_status3 = _usb_endp_init
#endif
'Reset the device ID to 0
_usb_deviceid = 0
Idlemode = 0
'******************** Действие по срабатыванию таймера 1 ***********************
Setflag:
'Нужно настроить на 12,5 Гц?!
Timer1 = 60000
Flaginputmsg = 1
