Вы здесь » Программирование ATMEL в BASCOM. » О программе BASCOM AVR/8051 » Application Notes - примеры с сайта
Сообщений 1 страница 2 из 2
BASCOM-AVR
Item Title        Hits
AN #149 - Sony Remote Control Decoding with BASCOM AVR  475
AN #148 - LCD display with touchscreen and AVR  2490
AN #147 - Car Windscreen Wiper Control with ATtiny13  5485
AN #146 - Loopback test  5564
AN #145 - Transfer data between MS Excel & MCU  8483
AN #144 - CodeLock AVR  6392
AN #143 - MCS Bootloader  7560
AN #142 - Using MAX1668 with BASCOM-AVR  5233
AN #141 - M8 Bootloader  4702
AN #140 - IR touch panel  6581
AN #139 - Using MCP23016  2537
AN #138 - RPM meter and rotational speed sensor KMI15/1 with AT90S2313  14067
AN #137 - Valentine Heart  2130
AN #136 - SmartCard4 Electronic Lock  2857
AN #135 - FlowMeter for ULM  2789
AN #134 - FAT32 WAVE Player  4818
AN #133 - 90S2313 Alarm Clock  4790
AN #132 - Interfacing an external I2C EEPROM for the T6963C Graphical Display  3967
AN #131 - Pseudo Multitasking in Real Time  2228
AN #130 - Using the AD7895-10 Bipolar AD converter  2002
AN #129 - Graphical Clock  4919
AN #128 - Moving LED messaging Waver with BI-colour LEDS  6402
An #127 - FAT16 File System Driver for CompactFlash  11308
AN #126 - Network programming with the NE2000  3437
AN #125 - How to set up zero crossing software to trigger a Triac  3495
AN #124 - SMS on Nokia 5110/6110 via microcontroller  6325
An #123 - Accessing a Compact Flash Card from BASCOM  5140
AN #122 - DCF-77 clock  4832
AN #121 - Showing custom fonts on the T6963C  2362
AN #120 - Sony IR receiver using the SIRCS protocol  2760
AN #119 - RC LapTimer  2221
AN #118 - I2C LCD and Keboard library  5163
AN #117 - Sending an SMS with the Siemens GSM M1 module  3117
AN #116 - Reading the SHT11 Humidity sensor  3331
AN #115 - Quadrature Decoder/Counter and Display  4153
AN #114 - Getting started in Data Transmission and Error detection with Correction  1990
AN #113 - Green House controller  3523
AN #112 - Speed controller for model boats  6160
AN #111 - Dual Thermometer with the DS18b20  5093
AN #110 - Dutch BASCOM-AVR course, AT90S2313 PDF in Dutch  2510
AN #109 - PID Controller  4989
AN #108 - BASCOM-AVR Hotchip cable  2831
AN #107 - Logarithmic bar graph (LED and LCD)  3296
AN #106 - A RealTime RTOS  3018
AN #105 - Sending RC5 and SONY IR codes  3487
AN #104 - Measuring temperature with 90S2313 and BASCOM-AVR  4652
AN #103 - Serial to GPIB converter  2631
AN #102 - Bit twiddle outputs on 74HC595 daisy chained shift registers to control relays  2441
AN #101 - BASCOM-AVR example that demonstrates SNAP protocol
BASCOM-8051
Item Title        Hits
AN #41 - Microcontroller-Based automatic flush system  1618
AN #36 - Micro Controller based Code Lock  2967
AN #35 - Low cost LCD frequency meter  10389
AN #34 - Micro Controller based Countdown Timer  3661
AN #37 - Micro Controller based alarm clock with DS1307 & MAX7219  2104
AN #38 - ADC using TLC549 serial 8bit IC  1371
AN #39 - Digital Thermometer-Cum controller with DS1821  2163
AN #40 - Infrared Proximity Distance Measurement  2283
AN #33 - SMS driven automat  2979
AN #32 - Realtime clock with LED display  4786
AN #31 - Sending SMS using Siemens GSM C35i  3424
AN #30 - RS-485 Master Slave Communication  3064
AN #29 - Remote Control a car by phone  2521
AN #28 - DCF-77 clock  2058
AN #27 - Count up/down timer  2006
AN #26 - LAB PLC  2172
AN #25 - Using the T6963 based GRAPHIC DISPLAY  2364
AN #24 - How to increase resolution of DS1821 temperature sensor  1371
AN #23 - Reading and writing the Dallas DS1991 secure I-button  1031
AN #22 - Two examples about Multi Tasking  1422
AN #21 - ASCII input with 3x4 keyboard matrix  1597
AN #20 - How to decode SONY IR remote control signals  2336
AN #19 - Using the LM75 temperature sensor  1808
AN #18 - Page scanner  1296
AN #17 - Telephonecard reader  1576
AN #16 - Using the Sharp GP2D02 distance sensor  1412
AN #15 - LCD VU meter  2042
AN #14 - How to implement a flow meter using the 80552  1009
AN #13 - Keyboard decoder  1796
AN #12 - Using the TIMER interrupt to make a clock with LED-display  1585
AN #11 - Using an I2C clock device with the PCF8583  2291
AN #10 - BASCOM-LT and BASCOM-8051 Hardware simulation  1473
AN #09 - Controlling the X9CMME  719
AN #08 - Flash Programmer  1906
AN #07 - Big Digit ThermoMeter  1641
AN #06 - Reading the DS1820 Temperature Sensor  2285
AN #05 - Reading an AT-PC Keyboard  2286
AN #04 - Reading the Dallas temperature sensor DS1821  1536
AN #03 - A Garden Watering Program  1271
AN #02 - Reading the TLC2543 A/D converter  1206
AN #01 - Evaluation board for the AT89C2051 and AT89C4051  2224
кривой перевод на русский
*149 - Расшифровка Дистанционного управления Sony с BASCOM AVR    1137
*148 - показ ЖИДКОКРИСТАЛЛИЧЕСКОГО МОНИТОРА с touchscreen и AVR 3428
*147 - Автомобильный Контроль(Управление) Дворника Ветрового стекла с ATtiny13 5759
*146 - Петлевой тест(испытание) 5860
*145 - данные Передачи(Перемещения) между Excel MS и MCU 8831
*144 - CodeLock AVR 6609
*143 - МЕГАГЕРЦЫ Bootloader 7876
*142 - Используя MAX1668 с BASCOM-AVR 5367
*141 - M8 Bootloader 4847
*140 - IR касаются группы 6817
*139 - Используя MCP23016 2622
*138 - метр ОБОРОТА В МИНУТУ и вращательный датчик скорости KMI15/1 с AT90S2313 14646
*137 - Валентайн Херт 2229
*136 - SmartCard4 Электронный Замок 2965
*135 - Расходомер для УЛЬМА 2901
*134 - Игрок ВОЛНЫ FAT32 5048
*133 - 90S2313 Будильник 4979
*132 - Установление связи с компьютером внешнего I2C EEPROM для Графического Показа T6963C 4180
*131 - Псевдо Мультиуправление задачами в режиме реального времени 2334
*130 - Используя Биполярное AD7895-10 нашей эры конвертер 2093
*129 - Графические Часы 5186
*128 - Перемещение ВЕДОМОГО передающего Колебания с ЦВЕТОВЫМ ВИСМУТОМ LEDS 6755
*127 - Водитель Системы Файла FAT16 для CompactFlash 11883
*126 - программирование Сети с NE2000 3588
*125 - Как настраивать(устанавливать) ноль, пересекающий программное обеспечение, чтобы вызвать Triac 3693
*124 - SMS на Nokia 5110/6110 через микродиспетчера 6598
*123 - Вызов к Компактной Карте Вспышки от BASCOM 5371
*122 - часы DCF-77 5023
*121 - Показ таможенных шрифтов на T6963C 2480
*120 - Sony приемник IR, используя протокол SIRCS 2880
*119 - ёМКОСТНО-РЕЗИСТИВНЫЙ LapTimer 2321
*118 - ЖИДКОКРИСТАЛЛИЧЕСКИЙ МОНИТОР I2C и библиотека Keboard 5445
*117 - Посылка SMS с Siemens GSM модуль M1 3267
*116 - Чтение датчика Влажности SHT11 3485
*115 - Декодер/Прилавок Квадратуры и Показ 4343
*114 - Начинающий в Передаче данных и Ошибочном обнаружении с Исправлением 2082
*113 - Зеленый диспетчер Дома 3709
*112 - диспетчер Скорости для образцовых лодок(судов) 6414
*111 - Двойной Термометр с DS18b20 5390
*110 - голландский курс(течение) BASCOM-AVR, AT90S2313 PDF на нидерландском языке 2632
*109 - ИЗОДРОМНЫЙ С ПРЕДВАРЕНИЕМ Диспетчер 5262
*108 - BASCOM-AVR Hotchip кабель 2957
*107 - Логарифмическая гистограмма (ВЕДОМЫЙ и ЖИДКОКРИСТАЛЛИЧЕСКИЙ МОНИТОР) 3467
*106 - RTOS В реальном времени 3168
*105 - Посылка RC5 и SONY кодексы(коды) IR 3662
*104 - Имеющая размеры температура с 90S2313 и BASCOM-AVR 4892
*103 - Последовательный на конвертер GPIB 2775
*102 - Бит(Частица) вертит продукции(выпуски) на 74HC595, маргаритка приковала сдвиговые регистры, чтобы управлять реле 2566
*101 - пример BASCOM-AVR, который демонстрирует ПОСПЕШНЫЙ протокол
